Question about Cables Unlimited SPK9110 Audio Unlimited 900MHz Wireless Stereo Headphones
No sound and green light on headphones doesn't light
Chat live
1) you must the headphones in any radio, for to see if the problem they are.
2) if they are o.k go control panel use the utility system restore put the last date that you know that was working.
God bless you
Jul 25, 2013 | Sony VAIO Computers & Internet
Sennheiser 120 green light goes off
Can you remove the rechargible batteries ? To try and reset them ? Or maybe replace them ? It sounds like the batteries have gone bad and not charging
Nov 12, 2017 | Sennheiser HDR 120 Consumer Headphones
Bose qc15 no sound
Try the headphones in another stereo and if it still has no sounds the the headphone cord or plug is faulty.
Apr 10, 2012 | Bose QC15 Headphones
I have a huge problem with these headphones (the Sennheiser HDR 120)... and my wife bought two of them... They have great sound on the computer, but once the green light turns off on the base? There...
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
Aug 12, 2011 | Sennheiser RS 120 Consumer Headphones
Green light is on but no sound coming out of speakers but green bar is moving in control panel/speakers/playback Can't figure out what to try next
Try using headphones in the socket that the speakers are connected to. If you hear sound on the headphones then the socket is working. If no sound then check you are using the correct socket - usually coloured lght green.
Feb 24, 2011 | Logitech LS11 Speaker 2 Speakers
Bose QC 2 Noise Cancelling Headphones the red light is on. Should there be a green light if they are working?
No green light for QC2, just red. If it's constant the battery is charged, powering the noise cancellation, and, if connected to an audio device, conducting sound. If the red light is blinking, the battery is losing its charge.
Nov 18, 2010 | Bose ® QuietComfort® 2 Acoustic...
When I connect my headhphone to monitor doesn`t work?
If you mean the pale green jack on the back of the monitor, it is not a headphone jack. It is to let you connect the sound output from your computer (usually also a green jack) to a little speaker in the monitor. That speaker is better than nothing, but sound quality is poor.
Jul 30, 2010 | Sharp LL 172A-B 17" LCD Monitor
There in no green light on RS 120. There is a red light on indicating that the headphone is being charged. Why I cannot use non-chargeable AAA batteries?
The green light only comes on when it is receiving an audio signal.
Standard batteries will work.. if you NEVER use the charging station.. and plan on replacing them every x number of hours used.. IMPORTANT.. if you forget.. and place the headset on the charging station with standard batteries.. they will probably rupture.. and may well ruin the headset..
If you decide to replace the chargable batteries.. make sure you replace them with the right size and type..
Jan 08, 2009 | Sennheiser RS 120 Consumer Headphones
Headphones has red light
Hello, I believe I just figured out the solution to this problem. I was experiencing the same thing, and as I was just showing my friend the problem I noticed that the green light came on after I turned on the music on my computer.
So, after removing the headphones from the base, the green light will come on only if there is sound playing from the computer (It takes a few seconds to turn on). It seems like they should have mentioned this somewhere in the manual...
Dec 04, 2007 | Sony MDR-RF970RK Headphones
Cables Unlimited SPK9110 Audio Unlimited 900MHz Wireless Stereo Headphones Logo
27 people viewed this question
Top Cables Unlimited Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cables Unlimited Audio Player and Recorder Expert? Answer questions, earn points and help others
