Question about Canon ZR100 Mini DV Digital Camcorder
No power bought new battery and charged it - still no power to camera - tried cord and household power also
3 Suggested Answers
SOURCE:
cpt100
  • 154 Answers
SOURCE: Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Posted on Mar 18, 2007
  • 62 Answers
SOURCE: i have i guess connetion problems
There are a few possibilities. One of the contact pins on the camera may be dirty or bent. The wiring coming from the pins to the circuit board inside the camera may be broken. A fuse inside of the camera may be blown (if there is a separate fuse for battery power). The battery even though it was charging for many hours may still be drained because it's old or defective - check the battery voltage with a digital volt meter to verify, and for absolute verification you should check the battery voltage under load when it's plugged into the camera and the camera is switched ON - is the voltage more or less constant or did the battery get loaded down and voltage level is now way below spec? Those in my mind would be the first few things to check.
Good luck.
Posted on Aug 21, 2008
I bought my Nikon Coolpix s3100 in the USA one week ago. It is my third Coolpix thought the years and I have been very happy with them. Now I am in Europe, with a plug to change from US to standard EUR....
I don't know where you got your information but, most of it is incorrect. Your camera can use two types of batteries: rechargeable EN-MH1 using the MH-70 battery charger or a non-rechargeable CRV3. The camera cannot be charged with a cord to the camera. Also, new EN-MH1 batteries will discharge quickly for the first few charges and then give good service thereafter.
Jul 22, 2011 | Nikon COOLPIX Cameras
My camera no longer powers on. I bought a new
Not using a camera much, along with time and chemical degradation within the battery itself, and oxidation on contacts both within the camera and on the battery, can cause this problem. It's always best to measure the voltage on a power cord with a voltmeter, but in your case it's probably good since it's new. In certain types of rechargeable batteries, you have to "recycle" them with at least 3 or 4 different charging periods. This is true for new or old ones that haven't been used much. It takes this to get them to fully charge. Make sure the battery is charged fully, if you try a new one, upon discovering a bad or shorted present battery. If it still doesn't work, clean the battery contacts both inside and outside the camera. They can be corroded slightly from battery leakage, or just oxidation from humidity over time. Use a pencil eraser, and wipe them with alcohol and a soft cloth or q-tip. Hopefully, you will have it working. If not, it could be a corroded contact pad on the on/off switch, or something even trickier. Make sure you get an estimate if you should elect to have it repaired. That will usually tell you whether it's time to buy a new one, as you're thinking, anyway. Try these simple things, you might get lucky. Good luck!
Apr 18, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
I have an acer aspire 3680 computer, Before the battery wasnt working so i bought a new one. Well now the battery came and i tried to charge it, but its not indicateing that its charging and won't charge...
Taking the fact that you already replaced the battery into consideration, chances are that you have a faulty cord. Looks like you're going to need a new one mate.
Sep 16, 2009 | Acer Aspire 3680 Laptop
Charging problems
The AC adapter is only used as an alternate power source for the camera. It is not intended to charge the battery for the camera in any way. In order to charge the camera's lithium battery you will need the charger that is designed for that battery.
Apr 11, 2009 | Olympus Stylus 600 Digital Camera
When charging my camera the charger light flashes red, green, orange and then it goes off. What does this mean?
battery issue try changing the batt they are not taking the charge pls replace if they got weaken or aged
pls rate me fixya if it helped
Mar 09, 2009 | Samsung Digimax L830 Digital Camera
Sony TRV-260 Has No Power
give this a try
taka pecil eraser and clean the contact points
Feb 03, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
PROBLEM WITH PENTAX OPTIO E10
It could be that the battery can't hold a charge anymore.
You will probably have to get a new battery.
Make sure the camera is working fine and that youre able to take pictures with the power cord plug in. If that works it isn't the camera, it's the battery.
Jun 20, 2008 | Pentax Optio E10 Digital Camera
Charging Battery
maybe your battery is dead, put your battery in your freezer for one night and charge it again.
Jan 21, 2008 | Video Cameras
Canon ZR100 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
