Question about Vehicle Parts & Accessories
My heater blower on the 2005 Chrysler pacifica only works sometimes
  • 336 Answers
Replace the resistor.
Posted on Mar 05, 2014
My heater blower on my 2005 Chrysler Pacifica doesn't blow air all the time it work one time and not the second time
When it won't work hit on the motor , if it starts to work the motor is the problem .
Dec 07, 2016 | 2005 Chrysler Pacifica
My AC and Heater blower isn't working in the front vents of my 2004 Chrysler Pacifica what is the problem
If the air blows out of all of your other vents then you have either had an actuator go bad which controls which ducts the air flows through, or the shaft that has the "flap" on it has popped loose and no longer moves which will only allow air to go to the vents that are not locked. The easiest way to find out would be to get under the dash and start at the fan and trace air flow til you find the problem.
Sep 11, 2012 | 2004 Chrysler Pacifica
I have a school auto shop trying to fix the heater in my chrysler pacifica heater . The blower motor wont work on any speed they checked the power and sais everything seemed to have power going to...
You need to specify if the car has Auto Temp Control or Manual......this is Manual. .Power is great, but its not going to work unless it also has ground. The black wire at the motor is ground, then it goes to the blower speed resistor, If you ground the Black wire, and the blower runs, the motor is OK, If you ground the Dark Blue /Gray wire it should work full speed. If it does not, then replace the resistor. The a/c controller grounds the Resistor. so if you ground the DB/GR wire and it works, then the controller may be bad. These guys should have access to a wiring diagram.
Dec 06, 2010 | 2005 Chrysler Pacifica
2005 Chrysler Pacific-no heat and no fan-display works
replace the complete heater control unit was my only fix! over $700 in Cnada for control.
Feb 17, 2010 | 2005 Chrysler Pacifica
I have a 2005 chrysler pacifica the heat and defrost stopped working no air at all is blowing out I checked the fuses and the relay both are okay what else can it be.
either your blower motor went bad or the blower motor resistor. what you can do is pull the plug from the blower motor and hook direct power from the battery and a ground, if the blower works replace the resistor the resistor will be mounted to the heater box close to the blower motor .follow the wires from the blower to the resistor. hope this helps
Feb 11, 2010 | 2005 Chrysler Pacifica
Heater fan works on high only (i have changed restor all ready )
If your blower motor is pulling to many amps it may have caused the resistor to fail again.
Mar 14, 2009 | 2005 Chrysler Pacifica
Heater blows full all the time
REPLACE THE BLOWER MOTOR SPEED CONTROL RESISTOR.
Feb 17, 2009 | 2005 Chrysler Pacifica
The LED light is out for the climate control on the AC.
i have seen this before and what i found to be the problem was the blower motor resistor block shorted out and kept the motor power up all the time. and would end up killing the battery. the resistor is located on the passenger side under the dash kinda behind the glove box
Jan 03, 2009 | 2005 Chrysler Pacifica
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
