Question about Home
What is the see through worm like creature that has a black head?
The worm is see through with a black head and you can see the insides of the worm, they live in my window seal that has standing water
    New Friend:
    Problem Solver:
  • 17 Answers
Biting midges no see ums Culicoides spp Biting midges can be a nuisance to campers, fishermen, hunters, hikers, gardeners, and others who spend time outdoors during early morning and evenings, and even during the daytime on cloudy days when winds are calm. They will readily bite humans; the bites are irritating, painful, and can cause long-lasting painful lesions for some people.
Posted on Apr 23, 2014
Engine runs tines dont
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
Jun 12, 2015 | Mantis 2-Cycle Tiller
How many input voltage do i need for my jbl creature ii.is it ac or dc?
JBL Creature needs a 18V, 3.5 Amp, AC power supply. JBL original power supply model is TA66180350-B2 made in China. In put power is 220-240V, 50 Hz-0.5 Amps. The AC supply is made to a dual rail supply inside the creature using a diode bridge.
Sep 08, 2014 | JBL CREATURE II Computer Speakers
What does invertebrate mean
An invertebrate is a creature without a spine. This includes worms, molluscs, insects, and other simpler creatures.
Apr 30, 2014 | Fish
I found a worm like creature hanging out in my window seal, it looks see through with a black head, when you touch them they curl up
biting midges no see ums Culicoides spp
Feb 15, 2014 | Home
Black does not print
Hi Yes you can try clean.
If it been standing for a long time ink wikk dry up on the heads.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Feb 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HP Officehet Pro L7650 all-in-One would not print any black,replaced black cartridge and it still will not print black ink, even though display reads full black cartridge
Feb 01, 2010 | HP Officejet Pro L7680 All-In-One Printer
When i print text doesnt get printed in black only in other colors
Hi
It only can be 1 or 2 things, it maybe you need a new black ink or the heads on the black ink is blocked, find out where the heads are and gave them a clean with a cloth with a little worm water and dabbing it on the heads it may do the job
Jan 28, 2010 | HP Photosmart C5280 Printer
Home Logo
187 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
