Question about Mtd Starter Housing Recoil Pull Cord Complete Assembly
Need pull cord assy w/cover for poulan pro pr55hy21ca self proppeled lawn mower
5 Suggested Answers
rburroak
  • 14 Answers
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
Posted on Jun 19, 2009
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
  • 100 Answers
SOURCE: Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Posted on Aug 14, 2010
  • 5 Answers
SOURCE: I have a Yard Machine Lawn mower by MTD it has a
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Posted on Oct 23, 2010
Why is cord is hard to pull on my poulan pro lawn mower?
Remove the recoil cover on the top of motor
& check it out
Aug 08, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Why won't Lawn mower pull cord rewind ?
the springs break when jerked too hard and more than the rope lenght
Jun 28, 2014 | Poulan Pro " Pro" Self Propelled Mower
Why does the pull cord is hard to pull and lawn mower won't start.
im betting the safety handle is not down far enough and is allowing blade brake to drag , also it's holding out ign ckt from working as well , those cables stretch all the time
Jun 18, 2014 | Poulan Pro " Pro" Self Propelled Mower
Pull cord snaps back
This is probably a "timing " issue. Either the flywheel key has maybe sheared or the valves need adjusting on the engine.
May 13, 2011 | Poulan Pro " Pro" Self Propelled Mower
Pull cord is stuck
Take off your cover to the pull cord, the cord probably just got wrapped around the pulley. If you run into trouble with taking off this cover go to smalleng.com they will walk you through the process off pull cord removal and installation. Good Luck PAL.
Jun 11, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Will not start
completly disconect self propled belt or gear should be able to mow til you fiigure out whats up with self pro some thing is jamming selfpro ps if you have to turn it upsidedown kill switch on
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
Where is the oil drain plug? I have a Poulan 600 pro self-propelled lawn mower and cannot find the oil drain plug to change the oil.
It is on the bottom of the engine. Lift up the deck and look under it. Make sure there's no grass covering it up.
Poulan mower throwing the belt.
1) Remove the cover on the top of the belt and
remove the belt from the transmission pulley
2) Lean the mower back on its handle and secure it
with whatever you have that will keep it there while
you work on it, any heavy object will do
3) Remove the blade bolt, the blade, the blade
adapter and the plastic belt guard from the bottom
You should now be able to remove the belt
4) While you have the belt off, closely inspect the
pulley on the engine shaft, they sometimes get
grass built up in the groove and this will cause
the belt to run off and also wear prematurely.
Hope this helps you out
Chuck
Mar 15, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Mtd Starter Housing Recoil Pull Cord Complete Assembly Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
