Question about Health & Beauty
Oster 6056 000 only one of two bars heatup can i do to fix
I need a manual for oster food dehydrator
go to the yahoo search bar and type in manual for oster food dehydrator if you have a make and model on it it will make the search more accurate ..in most cases you can find an online manual in a PDF file format...hope this helps.
Aug 26, 2012 | Oster Fpstdh0101 4tray Electric Food...
How to fix the switch on my oster 76 classic clippers
Check out My Video on how to replace Oster 76 Switch at Mannys-Sharpening.com Service You can Trust Since 1990
Jan 06, 2011 | Oster 76076-010 Hair Trimmer
I have an Oster Golden A5 2 speed. How do I
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Oct 01, 2009 | Oster Health & Beauty
I have an oster toaster that worked for about 8 months, then just recently it shows this error (err) aftr toasting for a min. do you know what i can do?
It sounds like you have the same problem as the Oster 6248 typically develops. The fix is to avoid ever buying anything made by Oster again, because it's all the same ****, made in China, just more overpriced.
Jul 14, 2009 | Oster 6239 Toaster Oven with Convection...
How do I change the blade on an oster 76 hair trimmer
What is missing in the "solutions" is the fact that you need to raise the bar with the guides on it that is part of the trimmer.  Depending upon how you removed the existing blade, the bar may be flat against the trimmer.  Take a flat head screwdriver and raise that guide.  Slide the new blade on and line up the slot at the cutting edge of the blade.  The whole problem is that the guide is likely flat which makes it impossible to install the new blade.  VERY POOR directions from Oster.
Sep 12, 2008 | Oster 76076-010 Hair Trimmer
I need to fix the rool of the pan Oster 5838 Bread machine
http://minneapolis.craigslist.org/hsh/574471930.html
Try this link, ther is a bread maker for sale used exellent shape.
Also try www.oster.com and contact customer service.
Feb 15, 2008 | Oster 5838 ExpressBake Bread Maker
Health & Beauty Logo
11 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
