Question about Toys
I bought the thunderfire exceed rc and the steering wheel on the remote is used as a throttle is that normal
    Problem Solver:
  • 5 Answers
Nope not normal. only solution i can think of is you have throttle servo plugged into steering slot on reciever.
Posted on Apr 15, 2014
3 Suggested Answers
  • 88 Answers
SOURCE: My RC Traxxas Stampede stop working. The steering
Spin the rear wheels and make sure nothing such as a small stone is binding something up in the driveline. Check to make sure the motor has not gotten disconnected from the ESC. If you still have problems with it post again and I will try to look further into it.
Posted on Dec 05, 2009
electrotech1
  • 1126 Answers
SOURCE: Brand new car (Exceed 1/10
It sounds like the receiver frequency is not set on the car to receice the signal, get a electronic tech to set itfor you or go to a hobby store they can set for you.
Posted on Sep 20, 2011
How do I fix the remote on the RC Thunder Tumbler RC Car to prevent the tire from spinning as soon as the remote control is turned on?
Use the throttle trim control to try and adjust this unwanted throttle application out. Refer to the user manual on how to trim the remote functions
Oct 17, 2016 | RC Thunder Tumbler Rc Car
Remote not working throttle or steering ,and remote keeps saying low battery but has brand new batteries
FAQ - Answers for Common Redcat RC Questions
www.redcatracing.com/FAQ
Q. I installed batteries in my car and in the remote control but when I turn on the power ... You may have some things such as throttle working but no steering. ... If it doesn"t your cord may have come off track and you can simply open the rear of ...
Why is my remote control not working? - Geardup RC Ford ...
https://www.ifixit.com/.../Why+is+my+remote+control+not+workin...
iFixitFeb 19, 2015 - To fix this, you can replace the batteries. ... The GEAR'D UP RC Ford Mustang GT is a remote controlled car released ... Is this a good question?
Troubleshooting an RC That Won't Run - Radio Controlled ...rcvehicles.about.com > ... > Troubleshooting, Repair, and MaintenanceRadio Controlled Vehicles Expert. Share ... The batteries are often at the root of manyRC problems. ... Loose or broken wires can result in a host of problems.Radio Control FAQ ' RC Toys ' New Bright
Dec 25, 2015 | Exceed-RC RC Truck
What are setings on controler
one adjusts steering from neutral (best) to a bit left or right, the other adjusts where trigger throttle will start breaking/reverse (keep in mind one does not need alot of speed in reverse so adjusting this so it acts more like a brake, and not throw you right into reverse is best)
Mar 23, 2013 | Exceed-RC Exceed RC Brushless Pro SunFire
Rc sunfire. remote works the steering but not the throttle.
try sync it to level 4 on it will turn green on full throtal I did it then I had to do it again because I charged the battery and had to sync it again try this when I did not do it second time it just stop tell me if that is the problem not a good discharge battery for 3000ninh 8.4
Sep 04, 2011 | Exceed-RC Exceed RC Brushless Pro SunFire
Problems with RC engine not running right!
Theres a idle screw located on engine under airfilter, should be small flat head. Clockwise will stop the carb from closing thus not cutting engine of. Also make sure you run car slightly richer than leaner. Hope this helps.
Mar 31, 2010 | Exceed-RC 1/8TH .21 Tectonic Nitro...
I need to know how to start my rc Exceed Titan! From start to finish! I bought it used. I also need to know what the switches mean on the remotecontrol! Also how to prime it!
ok you have to have the glo plug igniter for it and you only have to put your finger over the exaust for a sec or 2 as you turn over the eng then put the igniter on and start it if it is used it should be broke in
Mar 19, 2010 | Exceed-RC 1/8TH .21 Tectonic Nitro...
Exceed RC 1/10 4x4 truck transmitter or receiver problem
the antenna is not able to send the signal properly so repair or replace it
Jul 27, 2009 | Exceed-RC Dynamite Sava Red 1/10 Off Road...
Exceed-Rc Problem
go to rcdiscuss.com, it's a good place for nitro rc car beginner
Apr 05, 2009 | Toys
Toys Logo
24 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
