Question about Konica Minolta bizhub Office Equipment & Supplies
I have developQC2235plus error code C13d3 EEPROM access Y
  • Konica Minolta Master
  • 6,161 Answers
Well that mean you have a yellow image unit fault using 3rd party use only OEM. also check the yellow image unit.
Posted on Jan 18, 2016
110.4753 error code f01
I found this on the WEB-In reference to your Kenmore HE washer, model number 110.4753:
F-01 Error code
EEPROM ERROR
PUMP DRIVE ERROR
, or a
MAIN RELAY ERROR
EEPROM ERROR
: A communication error between the
Central Control Unit
(CCU) and the
EEPROM
onboard the
CCU
occurred.
PUMP DRIVE ERROR
: The pump driver fails to operate
MAIN RELAY ERROR
: One of the main relays is not working properly
Mar 31, 2014 | Kenmore HE2 Plus Front Load Washer
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Oct 18, 2013 | Sharp AL 1631 Copier
What is the error U2 ?
U2 04
Content: EEPROM read/write error (Serial communication error)
Detail: EEPROM access process error
Cause: EEPROM abnormality
Check and remedy: Check that the EEPROM is properly set.
Feb 10, 2011 | Sharp AR-M205 Copier
What is it when display reads malfunction code C2654 on a Konica 351 copier?
C2654 code means Black Imaging Unit eeprom access error.
A condition of "EEPROM is not connected" or
"There is an access error" is detected in
EEPROM of the Imaging Unit.
So the issue lies within your Black Imaging Unit. I would try sliding the imaging unit out partially, then re-installing. Reset by switching off the main power.
If this does not solve the error then you will need to call your local service provider.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 29, 2010 | Konica Minolta DiALTA Di200 Copier
Error code
These fault codes indicates an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board. Most likely the CCU board will need to be replaced.
Thank you !!
Jun 20, 2010 | Kenmore HE2 Plus Front Load Washer
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
We have a Sharp AR 207 and are getting an error message of U 2. How do we fix it. Do not have a manual.
U2
error
Detail-
Error in communication with
EEPROM
Cause
EEPROM failure
Installation of uninitialized EEPROM
MCU PWB EERPOM access
circuit failure
Check and
remedy-
properly set.
To prevent against loss of
counter/adjustment values, record
the values with simulation.
U2 trouble cancel with SIM 16
MCU PWB replacement
Mar 05, 2010 | Sharp Office Equipment & Supplies
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Sharp ar 405 u2-11 error
Content Counter check sum error (EEPROM)
Detail Checksum error in counter data area
Cause EEPROM defective
Control circuit hung up due to noise
Defective EEPROM access circuit on
PCU PWB
Check Check EEPROM for proper set-up
and To prevent the erasure of counter data
remedy and adjustment values, write down the
counter data and adjustment values by
simulation. (If there is a printer option,
execute SIM23-1 and note counter
data/adjustment values.)
Clear U2 trouble with SIM16.
Replace PCU PWB.
May 22, 2009 | Sharp AR-405 Printer
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Feb 10, 2009 | Kyocera Office Equipment & Supplies
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
