Question about Toshiba Satellite A135-S4407 PC Notebook
Toshiba Sattelite A135 S4407 Want to turn off touchpad, but FN F9 combination doesn't work
I'm trying to turn off my touchpad on my Toshiba Sattelite A135 S4407 I am aware to use the FN F9 combination however even though when I touch the FN button the light shows up to show it's working, that combination does not work. The FN key does work with other F keys. I just want to turn off my touchpad so I can use my wireless without worrying about the mouse jumping to a different place in a sentence when I'm typing. What other suggestions do you have? I also don't have that transparent bar that usually would appear at the top of the screen when you point to it. It doesn't show up on mine.
Crankstart
  • 696 Answers
SOURCE: wireless function key combination
Usually on the toshiba it is Fn and F2 or F4 the f key will have a coloured picture of an antenna with waves coming off of it.
Also most toshiba laptops have a physical switch on the edge of the case below the keyboard. Make sure that switch is on first then try the Fn and function key combo as they work together like a two way light switch. Both must be on for the card to be active.
Chris
Armor-IT
Posted on Apr 25, 2009
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite Touchpad not working
Restore the defaults in the BIOS to begin with, this will make sure its not a setting in there that is disabling the mousepad.
Then in windows see if the touchpad is working. If not then take the keyboard out with the power turned off.
When you take the keyboard out you will see the ribbon cable that comes from underneath the touchpad. disconnect it from the motherboard and reseat it firmly back in. Then turn back on the motherboard and see if the mousepad works. If it still doesn't then try the shortcut key to enable it.
If it does't enable then that means its either going to be a mousepad problem where you would have to replace the top cover assembly or a motherboard problem cause it could be where the voltage required to run that mousepad is missing.
Posted on Jun 27, 2009
SOURCE: frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Posted on Jul 08, 2009
sp4m771
  • 116 Answers
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
Posted on Jul 23, 2009
  • 67 Answers
SOURCE: the touchpad mouse on my toshiba salellite does
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Posted on Oct 09, 2009
Touchpad on laptop not working
There may be a switch somewhere on the laptop, or perhaps it's a combination of the fn key with another key, that turns off the touchpad. You may need to refer to the manual for more details. It might be fn+F9, but it depends on the model.
Mar 23, 2013 | Toshiba Satellite Computers & Internet
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
My keyboard and touchpad cursor are both frozen.
Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties in control panel
Mar 18, 2010 | Toshiba Satellite A135-S2246 Notebook
How do you unlock the mouse touch pad?
5. Go to http://support.toshiba.com there click on Downloads.. select your computer.. Product=Portable, Family=Satellite, Model=M35X-S149.. then click on "GO" button on the right.. Again in the next page that comes up click on "Downloads"..
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else.
Thanks for using fixya...
Sep 15, 2009 | HP Compaq nc6000 Notebook
My mouse button is lock how do i unlock it
5.Install Drivers
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Jun 25, 2009 | Computers & Internet
Frozen Cursor
Have you tried pressing <FN><F9>
May 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Touchpad
Have you tried FN+F9? on my toshiba to reactivate glide pad I have to use FN+F9
Apr 13, 2008 | Toshiba Satellite A135-S2276 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Mouse pad is not working
hi
can u enabling the touchpad by pressing Fn+F9,Fn+F7,.
Mar 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite A135-S4727 PC
First F8 and choose "last known good configuration".
Second, there is a small button atop the mousepad which turns the mouse on and off; might check that.
Good luck
Oct 15, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite  A135-S4407 PC Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
