Automatic shutdown every 10 minutes even if I disable it
Shutdown every 10 minutes even if I disabled it
    New Friend:
I don't know what to do but maybe you can call technical support to see if they can help
Posted on Feb 15, 2014
How to shutdown Cisco WS-C2960S-48LPS-L ?
Cisco's aren't like Juniper's - there's no "shutdown" command. if the pwoer is on, the switch will be on.
You can *disable* it by putting every interface into "shutdown" state if you wish.
And more information about Cisco WS-C2960S-48LPS-L:
c:\docume~1\admini~1\locals~1\temp\%w@gj$acof(tydyecokvdyb.pnghttp://www.3anetwork.com/cisco-ws-c2960s-48lps-l-price_p17.html
Feb 20, 2014 | Computers & Internet
Lan port shutdown automatically
I would suggest resetting to default settings and hit the F 10 key to save and exit.
Oct 21, 2013 | Asrock Computers & Internet
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
Hello, it takes my computer about 10 minutes to shut down
There might be a lot of programs installed on your computer and currently running, that may be the reason why you computer takes time to shutdown.
you can do perform a clean boot, your just going to disable a non microsoft program at startup. Please refer to the steps provided below:
- click start > run > type "msconfig" w/o qoutes press enter - click the services tab, then put a check on the checkbox (hide all microsoft services) then click disable all - go to startup tab > click disable all - click apply > then ok - restart the computer
Jul 13, 2011 | Computers & Internet
My laptop will just randomly turn off...it will run well for a few minutes and then just turn off and everytime i try to start it over it turns off even quicker...within a minute or two...i realy need help...
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Nov 02, 2010 | Acer Aspire 5315 Notebook
Similar problem on vista home premium
On vista the button on the start menu is a hibernate button not a shutdown, if you look to the side of the button you will see an arrow if you click this it will give you options such as shut down and reboot. this confused soo many people microsoft have changed it in the new version on windows.
To complelty disable your webcam you will need to go to control pannel- system settings - device manager then right click on the webcam and choose disable.
Jul 02, 2009 | Acer Aspire 5610-4648 Notebook
Not charging when it says charging
I was going to suggest a recalibrate might do this
with some machines run the battery to flat then fully charge at full charge shutdown and reboot windows.
With some machines the same thing is done as follows:
Enter the bios and disable the automatic shutdown for low battery. Disable the automatic shutdown for low battery in Windows. Run the laptop until it just dies from the battery going dead.
Charge the battery. Re-enable the automatic shutdowns.
And I believe some even have options in the Bios to recalibrate.
If this doesnt work then could be a voltage issue in the charger (is it universal with voltage settings?)
if it is this and no settings that could have been moved to wrong voltage etc, then maybe need testing and replacing.
Hope this helps
Jun 10, 2009 | Dell Inspiron 6400 Notebook
Override laptop automatic shutdown after inactivity
Easily done! Right click your desktop and choose Properties. Select the Screen Saver tab and at the bottom choose Power. In the Power Schemes drop down box choose Always On and the PC will never turn off. You might also want to disable or set the time higher for your screen saver.
Please rate this solution accordingly. Thanks for using Fixya.com.
Jan 10, 2009 | Dell Latitude D600 Notebook
Axim wont automatically shut off
I would guess your light should dim after 5 minutes. But I bet your axim wont shut off for 2,3, or 4 hours. My battery is wonderful so I have it shutting off after 2 hours.
Sep 14, 2005 | Dell Axim X5 Pocket PC
 Grubhead
Grubhead
