Samsung hlr6167wx xaa
Intermittent problem, control don't work, audio and video may freeze for short periods, timer is displayed when any control is pressed, also faint checker board pattern may be seen on screen. Controls work after several minutes, checkered pattern may still be seen at times.
    Genius:
  • 1,694 Answers
Bad main board part number BP94-01858A.
Posted on May 07, 2014
3 Suggested Answers
  • 31 Answers
SOURCE: Mitsubishi DLP WD-52525
your formatter board is bad. it can be repaired (sometimes) but they mostly just replace the part. hope that helps. need anything just ask
Posted on Apr 23, 2008
  • 4 Answers
SOURCE: Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Posted on Oct 21, 2008
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a samsung HLR6167WX/XAA dlp tv. I replaced the bulb, it worked for 1 day and didn't turn on the next day; no lights, no noises, nothing. So then I just replaced the ballast, still nothing.
Have you reset the lamp time after lamp replacement? If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 10, 2013 | Televison & Video
Samsung dlp hlr6167wx/xaa will not turn on
1) test the power supply for shot and open in the transformer+coil +filter+diode+rectifier+,fuse blown replace with the same capacity!+c.breaker tripped , reset.
2) test the HV horizontal output short or defective + Flyback short or defective Horizontal output +125Vdc+Vertical output +80Vdc+12Vdc colors+12vdc all other circuit for to CRT.
Remember the first thing do will have is RASTER.
God bless you. see the block.d
Aug 01, 2012 | Televison & Video
Samsung model#hlr6167wx/xaa replaced lamp,lamp and standby/temp still blinking. the bulb is new and turns on. just no picture
Ballast Board needs to be replaced it is what turns Lamp on. 1-800-638-3328 Be sure that Lamp Fan is running or TV will not come on.
Jun 26, 2010 | Televison & Video
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Replaced Digital Board on my Samsung HLR6167, picture is backward
call 1-800-samsung and they should walk you thru the programing, or they can help find the nearest service center.
Dec 01, 2009 | Televison & Video
TV Screen 'freezing' while watching.
Most likely the DMD board is at fault. If the DMD board is failing it will hold the data lines in the set down which will cause it to stay on until you unplug it. The part number for the DMD board is BP96-00249A but I suggest you have a technician verify the issue and replace the board as it requires mechanical alignment after wards. Please take a moment to rate my answer. Thank you.
Nov 18, 2009 | Samsung HLN437W 43" Rear Projection HDTV
Screen goes black and whte and freezes
Does it do it on all connections IE: DVD, Cabe, VCR? if it does than most likely a bad digital board in the TV. If only on one connection you see this then suspect intermittent connections to that device or a bad cable.
Aug 15, 2009 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
