Question about Lemax Village Collection Melinda Scone Tea Shop
Issue with Lemax Cosmic Swing music
Have you heard of any issues with the Lemax Cosmic Swing not playing the music? Or if there's a way I can fix it? Thank you!!
Cosco swing and play music plays but does not swing
Take it back they will replace it for you for up to 2 years.
Apr 25, 2014 | Cosco Juvenile Cosco Sway n Play Swing...
Hi Folks I think everyone thought I have a baby
I noticed another FixYa guru here answered a question on another strand that applies to yours:
Also, please note this person on FB claims to be the Lemax fix-all guru. You can ask them more specific questions:http://webcache.googleusercontent.com/search?q=cache:0YBPB3sM28kJ:https://www.facebook.com/eHobbyTools%3Ffilter%3D2+&cd=10&hl=en&ct=clnk&gl=us
The Knex website has building help for this problem. There answer is as follows:
Make sure all rods and connectors are fully hooked together, especially the blue and gray connectors. Even one peice not fully hooked together can twist the model just enough to jam the gears. (You may have it hooked together correctly prior to jam problems so it is good to check since I found a loose on holding the motor.) The chain links need to all be attached in the same direction, and fully hooked. The chain also needs to be on the tower with the hooks facing down and in as the chain runs on the outside of the tower. (Chain should be outside on the front and inside in the back with the 5 yellow bar side in the front.) Check that all gears are positioned correctly according to the instructions and the teeth facing the correct way. If you are still unable to get the seat to drop, you may remove the top yellow cross rod that the chain runs over - the model will also work with this piece removed.
I did all of these steps with my son and his still had trouble dropping all the time. It still seems light so the seat didn't have enough weight to drop with gravity during the non-moving cycle of the orange half gear. We decided to tape on 2 marble passengers to see if that helped. It did!!! When searching for other solutions, I noticed a UTube video that added people also so this seems to be a common solution. Try it or some other light weight added and see if it solves your problem.
Oct 06, 2013 | Scuba Diving & Snorkeling
Violin doesn't stay tuned
This is an intonation issue. If you can find a music store that works with violins, talk to someone there who will certainly be better informed than I am. At least they can tell you if it's worth your time to fix it, or more cost effective to replace it.
Apr 16, 2017 | Music
Cant play music files
check ur sound drivers, check that music palyer is working, download vlc player, download registry cleaner reg in out to fix the sound issue and media registry issue
Sep 15, 2010 | Computers & Internet
When i sync new music and try to play it it plays for 10 seconds then my zune freezes
Wipe the device. Update the firmware. Then re-add all your media (music) and try again.
If the problem persists you will need to contact Microsoft (Zune) about the problem because then you are dealing with a hardware issue and not a software issue. Hardware issues can only be fixed by professionals and support from Zune.
Mar 08, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Where can I get my Lemax Belmont Carousel fixed? I've only had it for two seasons and it is not working.
Hi
There is nor repair service for Lemax
I started in januarie 2010 a repair service on my own'
But have a difficulty with spare parts
sometimes i make spare parts on my own but this takes lots of ours to make it
And if the owner wants a chepa deal it is not possibel
most of the time it is cheaper to buy a new one.
But
Sometimes it is also a loose wire that is the problem
I made today two carousels
and one of the two is already ok
the other one needs a new spare part so i can not fix it at the moment til a have a donor carousel
Here in the netherlands all of the broken lemax items that are going back to the seller are being demoilisht or crached under a walz
I phone them if they would sel these items to me
but that is'n't possibel
so they make it hard for us repair nerds to help people like you
If you are living in the netherlands i ill thake a look at your carousel
if i can fix it it will cost you 20 euro/s
if not 10 for taking time with it
If you are living in england maybe you can send it to me by mail
I hope to here from you
John Bogers
The Lemax Doktor
Dec 28, 2009 | Lemax Toys
My speakers stopped working suddenly
Hello....No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with Windows OS....many of the users are facing this issue....
1 - r u facing NO Audio/Sound issue...?
2 - is ur Volume Control not responding ?
3 - is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
if ur ans to any one of them is Yes...then u are being spammed by Microsoft....ur Sound Control IRQ is being frozen by a recent update from Microsoft....NOTE..VERY..IMPORTANT...no file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it….
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service.
www+sureshayyar+110mb+com
Copy the above address in the browser, replace + with dots....
all the best...
Apr 15, 2009 | Inland ProSound 2000 Computer Speakers
I have a rainforest swing and everything on it
You can order the broken part and replace it. Call Fisher-price customer service and they will help you with that.
Apr 09, 2009 | Toys
Sound processing Difficulties
Dislodged centre speaker voided the circuit
Feb 19, 2008 | Onkyo Audio Players & Recorders
Connect Issue?
You need to make sure your using cable rated for use as Sub woofer don't use Audio or Digital Cables they're not the same.
Oct 20, 2007 | Samsung HT-DS1000 System
Lemax Village Collection Melinda Scone Tea Shop Logo
29 people viewed this question
Top Lemax Toys Experts
ray gallant
Are you a Lemax Toy Expert? Answer questions, earn points and help others
