Question about Thermos Grill2Go Fire+Ice
Unable to raise the grill. Pedal works but when pressed the grill doesn't raise. Can manually pull sides up but with difficulty. Checked the cable and it's fine. Tried wd-40 but that didn't work. Any other suggestions on how to fix?
3 Suggested Answers
SOURCE: pedal does not bring up grill
I believe you have to push down on the grill as you step on the pedal.
Posted on Nov 12, 2009
SOURCE: One side of the grill base will not rise up
One one side, there is a gas strut which is connected to the other side via a cable, similar to that which you would find on a bicycle for the brake. When the strut side raises (it uses this cable and a series of pulley's) it shortens the cable and raises the other side. With use, this cable where's and can slide off the pulley. It could also be that this cable has been damaged, although the prior is more likely the case. It's fairly easy to disassemble and inspect. One regular and one small philips screw driver, along with a pair of needle nose plier are all the tools necessary. If you would like further info. please let me know.
Posted on Jan 17, 2010
Passengers side electric window doesn't raise when toggle is pressed on main panel
if passenger window switch work passenger side window and driver side master switch dont. master switch either locked out or master driver window switch is bad.
Oct 25, 2012 | 2002 Jeep Liberty
Grill will not go up when you step on foot pedal. seems grill to heavy! what kind of adjustment is needed?
I am having the same problem. If I take the grill off and press the pedal the hydraulics work and the arms raise, but when the grill is on it won't lift - as if it's too heavy. I was wondering if it just needed some WD-40.
Sep 02, 2010 | Thermos Grill2Go Fire+Ice
Pulled latch, but hood won't open on 97 dodge ram van
If you pull out on hood release & it feels like some resistance cable is not broken. Have someone pull release & hold pulled outward while you hit the front of the hood near grill, with palms of your hands. If it releases upward, release 2nd catch. Raise hood & locate plastic or rubber hood stops. There is one on each side of hood screwed into radiator core support. Raise each one an even full turn. This will allow it to release properly.
Jun 23, 2010 | 1997 Dodge Ram 1500 Club Cab
Bonnet catch not releasing cable seems to have disengaged from catch end and cannot raise bonnet volkwagon t5 transporter dec 05 model
This is what needs to be done. Get a good torch and see what you can see through the grill - ( if yours is the model with a grill and not the folded over bonnet type ) . If it’s the grill type -you can usually see through there the run of the cable -- Remember which side the cable runs from inside the car from the handle - and then what you need to do is use long tools - usually long screwdriver or similar - and aim to shift the lock over to the side of the car that the cable would normally pull - Have someone with you if you can to get a hold of the edge of the bonnet to ease it very slightly up and down while you are working.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Feb 19, 2010 | 2002 Volkswagen Jetta TDI
One side of the grill base will not rise up when we hit the pedal. one side work, the other doesn't. any clue how to fix?we have put the grill on it and followed the instructions but only only side goes...
Nov 21, 2009 | Thermos Grill2Go Fire+Ice
Pedal does not bring up grill i have to take grill off and pull up manually any way to fix?
If you can still raise it manually, it probably needs new hydraulic struts. Mine actually never worked from new, and I am taking mine apart today to fix it. I will let you know what the part number is of the strut.
Aug 27, 2009 | Thermos Grill2Go Fire+Ice
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Ice despenser in side by side door, kenmore does not work
Pull the grill cover off near the floor and look to see if any of the wires have been cut. I found that the grill cover wore on the wires controlling the door functions. First the crushed ice function went, then the water dispenser went. I had splice the wires back together and am leaving the grill cover off. No problems since.
Jan 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
My Grill will no longer lift
I just had mine apart today because the cable broke. There is only one damper, in the left side where the pedal is. The other side is controlled by a cable that is strung on rollers. My cble broke so i had to replace it with one from a hardware store. I noticed that everything needs to be oiled for the system to work good. The gas strut/damper is inside of the lift tube. I would think it could be matched up with one from an automotive store. Autozone has a pretty good selection of them. But, The strut that is in the grill has a special end on it to fit the lift tube, you would have to somehow fabricate a new end or try to cut and weld or braze the old one onto the new strut. I have not had the strut problem yet because when I store the grill I leave it in the up position. this takes the stress and pressure off of the strut. Hope this helps.
Sep 26, 2008 | Thermos Grill2Go Fire+Ice
The hood latch cable on my 1972 corvette broke. How can i open the hood?
Remove the honey comb grill from the drivers side and you can reach in and release the hood
Jul 29, 2008 | Chevrolet Corvette Cars & Trucks
Thermos Grill2Go Fire+Ice Logo
81 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
