Question about Pentax Cameras
Pentax k2000 won't save time and date
It worked fine. I took the batteries out to charge. It would not turn on with my rechargeables. I put in regular batteries. It will now turn on and take pictures, but won't keep the time and date. Every time it shuts off, you have to reprogram it.
    Top Expert:
  • Pentax Master
  • 6,702 Answers
In most modern cameras is a little rechargeable battery, that keeps the clock ticking. If your camera was a long time without power, perhaps this battery has died. I would buy a new set NiMH rechargeable or recyclo batteries, because they have a bit less capacity, but can hold power for as long as a year. Then charge them and leave the rechargeable batteries in your camera. Keep your fingers crossed, perhaps the little clock battery will be revived?
Posted on Feb 15, 2014
  • 374 Answers
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Posted on Mar 30, 2008
SOURCE: Kodak z1275 easy share camera
never use kodak again!!!
Posted on Dec 17, 2008
SOURCE: Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Posted on Jan 23, 2009
wicabuss
  • 48 Answers
SOURCE: On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Posted on May 01, 2009
  • 11967 Answers
SOURCE: won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Dec 17, 2009
Pentax K2000 DSLR stopped working after using manual K-mount lenses?
Have a look on Pentax Forums as a guest - you may find something there
Oct 17, 2017 | Pentax Cameras
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
Oct 24, 2012 | Pentax Optio Cameras
My card is locked on my K2000. How do I unlock it?
There is a sliding switch on the SD card marked 'lock'. Slide it up to unlock the card.
Dec 03, 2011 | Pentax K2000 Digital Camera
Won't switch on. Was working fine; battery running low so removed it to recharge as I have done many times before. On reinstalling battery the camera is completely dead.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 28, 2011 | Pentax Optio A30 Digital Camera
Power / batteries
This is a common problem...sometimes you have to turn it on a couple of times.
Mar 17, 2010 | Pentax *ist DL Digital Camera
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
Jun 21, 2009 | Pentax K200D 10 Megapixel Digital SLR...
Batteries
mmmm.... thats a weird problem :)  Yes definatly try those other rechargable batteries that you where thinking of buying, the batteries could be duds??  other than that, if it is under warrnty send it back to pentax with the batteries and tell them the problem.
Oct 31, 2007 | Pentax K110D Digital Camera
Date/time problem on *ist d
There is a small re-chargeble battery inside the camera that charges of the main battery. Chances are that battery had just drained when the date/time reset occured, but should be fine after you recharge.
Sep 08, 2005 | Pentax *ist D Digital Camera
Cameras Logo
79 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
