Question about HP dv7t Notebook
HP Dv7t won't shut down properly
My HP dv7t laptop will not shut down properly. When I try to shut it down, the screen just goes black with some of the keyboard lights still on.
    Top Expert:
  • HP Master
  • 22,788 Answers
I would run a registry cleaning programme first. It may be just looping.
Posted on Feb 15, 2014
4 Suggested Answers
  • 1257 Answers
SOURCE: My hp dv9000 won't shut down completely!
Update windows using update.microsoft.com and see if you have all the latest drivers in device manager for all the hardware connected..If still not resolved then backup the data and perform recovery.
Posted on Mar 06, 2009
Geekman
  • 32281 Answers
SOURCE: hp dv2210us power goes on but just black screen, not booting up
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 20, 2009
linswad
  • 258 Answers
SOURCE: MY COMPUTER WON
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Posted on Apr 16, 2010
How to reload HP Pavillion dv7t disc backup
You need to get the Recovery CD for your model Pavillion laptop from the HP WEB site. Then you boot up the HP laptop with this Recovery CD and follow the instructions.
http://welcome.hp.com/country/au/en/cs/support.html
Mar 30, 2013 | HP Pavilion Computers & Internet
I HAVE PROBLEM WITH MY HARD DISCK.
Can you tell me detail , what the problems my friend ?
Jun 21, 2011 | HP dv7t Notebook
I have a hp dv7t (brand new) and the num lock does not have an idicator light to tell if its on or off. HP tech says that is normal cause that model does not have that featrure. Do you if that is the...
Looks like the tech is right. HP now only gives you the option of seeing the num lock on or off by using the HP software on your computer.
see dgobes response in this forum:
http://forum.notebookreview.com/hp-pavilion-notebooks/562249-hp-dv6t-dv7t-select-edition-quad-edition-6xxx-series-owners-lounge-498.html
Please rate my review to show your appreciation!
For more tips visit my blog at http://thegeektweet.wordpress.com
Jun 05, 2011 | HP dv7t Notebook
Hi, I spilled a large quantity of water on my HP dv7t laptop last night. It was a huge glass, and because of this the laptop just automatically shut off and i didn't even have time to turn it off. I...
I am assuming your motherboard is fried, but your Hard Drive is still OK. The laptop may not work anymore, but your files are more than likely recoverable.
Apr 17, 2011 | HP Pavilion DV7T 17" Laptop
Hp pavilion laptop bad video out color distorted
This sounds like the usual HP problem. Commonly the graphics chip overheats on these and eventually goes. To verify this:
1.) Check using an external monitor, if thsi works ok, fault is with the VGA cable on the laptop or the screen
2.) If fault persists, the issue is with the graphics chip. In which case, strip the laptop and clean out the cooling fan, matrix and (if you feel confident), remove the heatsink assemnly and clean and replace the heatsink compound on the CPU, ensure that the thermal pad on the graphics chip is intact and tighten the screws thoroughly.
If that fails, I'm afraid the graphics chip will need reballing
Mar 26, 2011 | HP dv7t Notebook
Using Windows 7, relatively new HP Pavilion dv7. About a week ago a Memory Dump blue screen started appearing spontaneously, would stay on for only a very few seconds, then restart the computer. There...
hi
memory dump is the result of bad memory module (RAM).. remove the ram modules, look at them, make sure they are same make and part. different manufactures can often cause memory fault in a system
if that's the case, replace the memory modules . you can go to the link below and select the model you have, go to KEYWORD selection, and select MEMORY DIMM, it will then give you the part number you need to replace .
if you need more help, please don't hesitate to issue 4 thumbs and i will give you further details and cost of the modules. you can easily purchase at a link i will issue at that time.
http://h20141.www2.hp.com/Hpparts/Search_Multi_Product.aspx?mscssid=49A90DD091EA4D89B2FC957BD1525074&SearchCriteria=dv7t
please issue 4 thumbs up
Jan 07, 2011 | HP Pavilion dv7t PC Notebook
Very choppy video on HP DV7T Vista 64 bit
If you are happy with it running on a different OS try running it in Compatibility Mode
Right click on the desktop camera icon
Select 'Properties'
Select 'Compatibility' tab
Check the CM mode box and select the OS from the dropdown box
Click 'Apply' & 'OK'
May 23, 2010 | Logitech QuickCam Pro 9000 Web Cam
I have an HP dv7t laptop. The screen does not light up
Maybe the backlight has failed on the computer .
Oct 21, 2009 | Computers & Internet
HP dv7t Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
