Question about KitchenAid Architect Series KEBC208KSS Electric Double Oven
I have a KitchenAid Double oven KEBC208KSS02. The fan makes a loud noise from the time i turn on the oven (same for either the upper or the lower unit) until a few minutes after I turn it off. Everything works fine - just the noise.
    Prodigy:
    An expert who has answered 500 questions.
  • KitchenAid Expert
  • 650 Answers
It sounds like the fan itself is bad. they can get loose and start to rattle or rub against the frame.
Posted on Mar 02, 2014
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
I used the self-cleaning feature and now my oven will not turn back on.
Their is a high limit thermostat that has tripped,on older model and on some newer models it has a red button on it that can be pushed in to reset it.Other times once it goes out it must be replaced.
For the upper oven its behind the control panel,for the lower its behind the grill between upper and lower oven
I hope this helps you to understand why your oven wont heat,
Gene
Aug 05, 2011 | KitchenAid Architect KEBS207S Electric...
We have had nothing but problems with this oven - what a lemon!!!! We have had the computer replaced 5 times in the short time we have had this. Now, our top oven is not heating. The repair man says we...
Absolutly could of course be the EOC (electronic oven control) since it does control both the upper and lower over. Sorry for your luck but just because a part has a high failure rate that manufacture isnt required ti issue a recall as long as thier isnt a saftey issue such as potential fire or what have ye
Jul 23, 2011 | KitchenAid Architect Series KEBC208KSS...
I have a kitchenaid KEBC208 Built in double oven. The cooling fan makes noise. It stays on long after the oven is turned off and we sit in the kitchen and have to listen to it while we eat dinner. Can you...
Hello. look in the yellow pages of your phone book for appliance repair. Find a store that sells or repairs kitchen aid. There are several possible causes for the problems you site. Only a trained repairman with the proper scanners and tools can isolate and fix your oven.
Aug 28, 2009 | KitchenAid KEBC208 Electric Double Oven
KitchenAid Architect Series KEBC278KSS Electric Double Oven displ
Our fan on our oven is super loud. Always has been. We have to keep the door open so that it will cool off asap because it is so loud. What's wrong?
Mar 11, 2009 | KitchenAid Architect Series KEBC278KSS...
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
516 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
