Question about Poulan Garden
How to Change chain on Poulan pro PP5020AV
Change saw blade
    New Friend:
  • 4 Answers
Most chain saws have on their right side either a knob or two nuts that loosen the bar so you can push it back to allow slack in the chain. The knob may have a flip latch that locks in place, and you flip over to allow you to turn the knob counter clockwise.
make sure the start switch is off first
Posted on Feb 19, 2014
4 Suggested Answers
Editor925
  • 285 Answers
SOURCE: chain keeps turning while in the idle position
There will be an idle (Low) speed adjustment screw somewhere on the saw (look in your manual). Adjusting this setting lower will prevent the chainsaw chain from turning in the idle throttle position. Basically you want to set it so the chain has just stopped moving... but you need to set this after the chainsaw has warmed up a little.
Posted on Mar 13, 2009
  • 398 Answers
SOURCE: I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Posted on Mar 21, 2009
nedkelly900
  • 345 Answers
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Posted on Apr 28, 2010
Choke soses choke engages and saw dies out when using saw
Choke leaver worn at carby or the lock off position worn.
Sep 19, 2016 | Poulan Pro PP5020AV 50 cc Gas Powered...
POULAN 50CC CHAINSAW
Try chainsawr.com
CHAINSAWR.COM ....don't forget the R at the end... caps or small, it doesn't matter.
Mar 10, 2015 | Poulan Pro PP5020AV 50 cc Gas Powered...
My Poulan Pro PP5020av 50cc chain saw won't start
I had a popular. If you put the chain on to tight it won't start.
Nov 08, 2014 | Poulan Garden
#pp5020av pull cord
The length of the Starter pull cord is 40"
It can be purchased at www.ereplacement parts.com
I have no affiliation with this site or company. They simply have great prices and also list exploded views of this saw and others.
http://www.ereplacementparts.com/poulan-pp5020av-stroke-gas-chainsaw-parts-c-16962_17147_162366.html
Aug 04, 2014 | Poulan Pro Pp5020av Gas Chain Saw 20" 50cc...
What is the replacemnet cord size for my #pp5020av
www.ereplacementparts.com lists the part as Kit Rope 40" (Type 4.5)
Part Number: 530069919 Priced at $2.84 and if you need a new handle, it's only $2.73
The link is below.
Aug 04, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
How to tighten chain
Srew under blade and chaine. Make sure the tightner is align with is slot. Then secure cap with the two bolt lightly fist. Then srew the flat srew until chain is tight. Just enought that you can move the chain by hand. Then tighten the bolt (Nice snug fit) Please do not use impact.
May 24, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
How do I remove the bar on my Poulan Pro PP5020AV
by undo'ing the nut on the side over top of bar , then the entire case cover should lift off that side and then the clutch is visible , slacking up on chain tension screw till the chain can round the clutch and then entire bar and chain should just fall away
Sep 07, 2012 | Poulan Pro PP5020AV 50 cc Gas Powered...
Garden Logo
122 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
