Question about Fisher and Paykel Washing Machines
Connecting motor controller in gw11 washer
We are replacing the motor controller to our Fisher and Paykel gw11 washer. F&P have a replaced the motor controller with a slightly different motor controller. We need to figure out where the display cords tie into the display module. Any information would be appreciated! Sean & Cindy
  • Fisher and P... Expert
  • 554 Answers
There is raised print below the socket with the name for the plug that goes in that socket.
Posted on Apr 21, 2014
  • 351 Answers
SOURCE: Need to replace drain hose
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
Posted on Mar 09, 2008
  • 30 Answers
SOURCE: power wont go on fisher paykel eco smart GW11
first step is to make sure you do have power to your washing machine.
if you press your power button and you dont get any response,you will find the your electronic have gone.
Its called a power module.
They do have fuses in them.
Posted on Jul 31, 2008
RescueTech
  • 145 Answers
SOURCE: ecosmart gw11 fisher paykel
Hello and welcome. Couple things to check first-
Tip the machine back and look underneath at the water pump, if it is wet or appears crusty/corroded, you probably have a shorted pump that took the machine control out along with it. Sometimes you can just replace the pump but on those models the board can become a casualty. Also look at the control itself and check for water in the pan area underneath it. Sometimes the mixing chamber thermistor leaks and it will short out the machine control. Whenever you replace the control, a new seal should be put on the thermistor. (easy and cheap insurance)
You might want to start with a fisher paykel gwl11 service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=17
Posted on Dec 18, 2008
  • 93 Answers
SOURCE: no power to fisher paykel washer. Replaced pump
PUMP IS ALSO A HEAT SINK FOR THE MOTOR CONTOLLER.
YOU MAY NEED A NEW BOARD
Posted on Jul 10, 2009
SOURCE: Fisher & Paykel washer IW712: fault code 105
Fault codes sheet is located under the dryer control cover.
Fault Code 105 Communications Error Time Out - I&A
Communications failure between the sensor module and display module. (loose wire). 1).Visually check the contacts on the RAST (edge) connector at each end on the harness between the sensor and the display module. 2). Replace sensor module and/or display module and/or harness.
Posted on Dec 12, 2009
Gw11 stops mid cycle and beeps and lights 2 and 7 are lit up anybody know what the error code is
Is it model GWL11? There is no model GW11. On most other models that code indicates there is a fault in the water pressure transducer which measures the water level. Unfortunately the motor controller module needs to be replaced.
Nov 06, 2014 | Fisher and Paykel Washing Machines
Why does the fisher and paykel washer gw11 drip water after cyle is finished?
If it drips inside than check and replace fill valve.
If it drips onto the floor check for a leak
Jun 05, 2014 | Fisher and Paykel Washing Machines
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jul 23, 2012 | Fisher and Paykel Fisher & Paykel Washer
My GW11 washer isn't working and keeps beeping
Your first code was 136
Second code is 130
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. Nominal resistance should be around 32Ohms.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and basket by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Tertiary Source: Motor Control Module.
Action: If the primary and secondary checks pass inspection, then replace
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Jun 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washer keeps saying cutoff restart
The power supply is faulty in the motor controller.
Replace motor controller with new/Reconditioned board.
Apr 25, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel GW509 won't power up, pump not blocked, plug loose?
62. (00111110) Phase 5 - Pump Over Current
The Motor Controller module has detected an excessive pump current.
Primary Source: Pump.
Action:
Replace Pump.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module.
107. (01101011) Phase 2 to 6 - Motor Controller module Reset Error
The Display Module has detected that the Motor Controller module has reset when
it should not have. This can be due to a Motor Controller module supply
disturbance or microprocessor failure.
Primary source: Motor Controller module.
Action: Replace Motor Controller module.
Red, Blue, Yellow go on the motor
Brown , White go on the pump.
Apr 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
Have Fisher & Paykel washer GW11. 5 yrs old. Lid won't lock, Took off to repair, then put back on, no problem, but now won't lock, so won't spin. Help!
your door needs to be re-aligned so the wax motor assy can lock the door so the unit senses its locked and can continue the wash cycles
Jul 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Where can you find a fisher paykel GW11 pump for $25 as quoted in your response? Thanks!
go online to fisher & paykel factory parts search and you have to look but they are in there I dont remember $25.00 but its close
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Ecosmart gw11 fisher paykel
Dec 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
