Question about Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WM52 first Edition
It will wash my clothes just fine but when it comes to spinning them it wont. I have had the bushes done about a year ago when the drum would not turn at all, But now the drum turns untill it tries to go on to the fast spin where the drum stops and there is clicking from the front but then it turns the nob to the off position. Any advice is very welcome.
  • 3 more comments
  • dougal123 May 22, 2008
    MACHINE TRIES TO RINSE AND SPIN BUT WONT
  • Anonymous Nov 14, 2008
    drum wont spin
  • nconn Nov 30, 2008
    drum wont turn and i have changed th brushes
  • wanda1234 Feb 10, 2009
    my wm52 is tripping mains switch as soon as it is turned on, can you help me with this?
  • rob_ang_weav Feb 17, 2009
    But how do you replace the brushes?
  • Hotpoint Master
  • 3,463 Answers
I think you will find that if you check the brushes, you will probably need to replace them.
Posted on Dec 04, 2008
Hotpoint washing machine not spinning with clothes in it
Its either going to be your clutch/brake assembly or the transmission. Both ways are a nightmare to do, and if you've never done one its not something to try for the first time and honestly, being a hotpoint its not cost effective to have a technician come to home and do it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Hotpoint Washing Machines
Hotpoint pump
Is the machine not spinning? May need new bushes. Sited underneath and wear down by making contact on drum.
Feb 05, 2012 | Hotpoint Aquarius WF210 Front Load Washer
Stopping mid cycle, not taking softner, doing a
OKAY.....Could be cold water not entering the machine , due to turned off. or faulty valve coil not too expensive to fix...
May 24, 2010 | Washing Machines
Zanussi FJS 1425W - the machine is not spinning the clothes so clothes are quite wet when they are washed so have to spin but this is also not working well - washing purchased approx 7 yrs ago -
hotpoint top loading washing machine serial number TS182924N MODEL NUMBER HNXR1060T8WW. machine won't spin and will not empty water, just a humming noise. number on scamatic diagram 175D275OGO71 MACHINE IS APROX 20 YEARS OLD
Jan 06, 2010 | Zanussi Washing Machines
Hotpoint WMA20 will not fast spin
It is rare that it would be the bearings as there would be play in the tub, it would be noisy and would probably leak. There is a small electrical box in the bottom of the machine. This is the speed control for the motor. You will also find the wireing diagram in a plastic bag in this location. You can check to see which wires require current to activate the different speeds.
I hope this helps.
Dec 28, 2009 | Hotpoint First Edition WMA20 Front Load...
I have a Hotpoint WM52 that fills but will not spin / rinse
Check the brushes in the motor, and replace if less than 5mm or or so in length.
Please rate my solution.
Thanks.
Aug 11, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
WF860 doesn't clean the clothes at all!
Lack of water in wash cycles. possibly due to blocked filters in water valves where hoses connect to machine or faulty water valve, normally cold inlet is the main problem
Mar 30, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint First Edition 1000 WM52
I had same problem. Had to replace brushes on motor. Easy enough job to do yourself
Jan 04, 2009 | Hotpoint First Edition WMA12 Front Load...
Hotpoint First Edition 1000 WM52 the turner thing for different washes is very hard to turn now, the machine seems to struggle.
Hi.
It sounds like the timer is stiff, remove top cover, and spray WD40 liberally over and into the timer unit at the front right of the m/c.
If the motor is struggling to turn then you have another problem as well.
Good luck.
Nov 23, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WMA52 Front Load Washer Logo
598 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
