Question about Radio Communications
I have a Phillips SE 450 with a headphone jack. Whenever I try to use the headphones I can hear the other party but they cannot hear me. I need to use the phone to do interviews via the internet, but
Need other party to hear me when using headset
jerryg50
  • 1667 Answers
SOURCE: logitech usb headset a-0356a trouble hearing
I don't have these headsets here and the setup to troubleshoot for your fault. But, I have an opinion.
It seems that the driver for the headset is not routing the sound from the net or other applications to the USB ports, as like with the sound from the media player.
For IE, look in the advanced settings for media and see if there is a setting for this. Also, check out all the media settings in the system for this.
I would search out the properties of the headset to see if there is a setting for this. Also search out the properties of the sound card where it allows for USB and regular sound sharing or routing.
I would also get in touch with the manufacture of this headset to find out if they know something or have a solution.
Jerry G.
Posted on Apr 13, 2008
SOURCE: Blackberry 8800 headphones aren't working
The 8800 does not support the stereo function on headphones.
Here is the ATT thread: http://forums.wireless.att.com/cng/board/message?board.id=rim&thread.id=22479
Posted on Jul 02, 2008
wealthwise
  • 111 Answers
SOURCE: Cannot use microphone.
Hi I have had a similar problem with a Mic, too things to try , first try it on a different appliance to rule out the appliance you are using, if it still doesn't work then it's most likely a short somewhere, tough to repair but worth a shot if you have the patience.
Hope this helps.
Posted on Dec 06, 2008
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
SOURCE: Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Posted on Jun 20, 2009
Whenever I start the computer, I dont hear any sound from window and if I try to play music from my media player, no sound at all. I can only listen to music or sound via headphone only. I have downloaded...
most system has seperate audio ports for the speaker and the headphone but they are interchangeable. try plugging the speaker on the audio your using for the headphone. if your already using the same audio jack then try using another speaker, but since you mentioned that the headphone works then its possible you might need to replace your speaker
Mar 29, 2011 | HP Computers & Internet
Every time i put my right head phone in my ear there is a crinkling sound tht comes from inside the headphone, it does not effect sound quality bt it is very annoying -.- (cnrinkle can also be heard...
have you tried the headphones on another device? cause this issue could be caused by many things
The underlying hum or static you hear is probably due to poor shielding on the audio jack, so the electromagnetic field produced by the hardware can cause interference.
This could also be caused by a loose connection in the audio jack. This is actually a problem with all skull candy headphones of this kind. You can google it and see alot of people have this problem. Best to test it on 3 devices. If it works on the other 2 and not yours it is your device. If it does it on all 3 it is the headphones. If you just bought them skull candy headphones come with a 90 day warranty up to 1 year. if its in the first 30 days return them and either get a new pair or get your money back.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. thanks and have a great day.
Aug 17, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Headphone jack
You must have not plugged in it properly, force the jack till the end of the socket so it locks in with a click, then it will work fine.
Jun 07, 2010 | Audio Players & Recorders
The jack will not fit in my tv
There are lots of different sized jack plug adapters on the market, you should be able to find one to do the job. I would try Amazon first, they have a good range and decent pictures of products.
Feb 11, 2010 | RCA WHP141 Consumer Headphones
No sound without headphones
i had the same prob. just try blowing into the headphone jack or unplugging and plugging back in the headphones into the headphone jack a couple of times. there must be some sort of problem with the headphone jack that makes the phone think that the headphones are still in or something.
Jun 24, 2009 | Samsung Eternity Cell Phone
Audio/sound problems
sounds (pun intended) like you have your headphones plugged into the microphone input. See if you can change the spot they are plugged in...
good luck
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
Headphone out jack is really quiet.
If you're trying to plug the speakers into the headphone connector that will happen.
Headphones are having a high impedance and those loudspeakers a low impedance.
That's why your volume is down. It stresses your audio-amplifier and even blow your finals.
Cheers,
Gerard
Jan 30, 2009 | Televison & Video
Ipod Headphone jack is damaged
Hey mas2514,
If the headphone jack of your iPod is no longer functioning, it can sometimes be repaired or replaced. The cost to repair or replace the headphone jack does vary depending on the iPod model, and if the product is still covered by the manufacturer's warranty or some kind of third-party coverage (such as the Best Buy Performance Service Plan, or PSP).
If you are unsure what kind of coverage your iPod currently has, I would first suggest contacting Apple directly for technical support or speaking with a Geek Squad® agent at your local Best Buy™ store for further assistance. Either of these parties should be able to provide you with a detailed diagnostic, as well as an estimate for repairs if you no longer have any kind of warranty or service plan coverage on the unit.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 20, 2008 | Apple iPod MA446LL/A MP3 Player
Radio Communications Logo
13 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
