Question about Honeywell Computers & Internet
Scanner is not coming on with computer - Honeywell Computers & Internet
    Genius:
  • 1,552 Answers
Is the scanner turned on and connected via the USB cable when Windows starts?
Posted on Mar 23, 2014
HOW TO INSTALL OF MY SCANNER?
to install your scanner into the computer,connect the scanner USB to computer usb input. insert the installation disk( that comes with your scanner package)into the CD rom drives the computer will now the installation wizard then just follow the instruction given by the wizard..good luck
Dec 18, 2010 | Kitchen Appliances - Others
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
My screen comes up with the Insfficient memory
it could be ether hardware or software problem. try installing the scanner on a friends computer and see if it does the same thing. if it does then your scanner if faulty, if not then try uninstalling you scanner drivers restart your computer and go to http://www.mustek.com.tw/Download/driv_scanr/europe/b4800tapro.html
to download the new drivers to reinstall.
Aug 18, 2009 | Mustek Bear Paw 4800 TA Pro Flatbed...
Trying to erase a light with a scanner
There is no real place where scanners come up except when they are plugged in. Once plugged in they should come up in device manager which you can access by right clicking My Computer select Manage Computer and you will see the Device Manager. Once selected you will see all the hardware devices connected to your computer. Under Scanners should be the scanner wich you can then right click and choose uninstall.
To connect a scanner simply plug it in and use the CD it came with to install the driver and software which should pick up the device and add it. The scanner software itself is what picks up the scanners and alows you to use there functionality.
What is it your trying to do re-install, add, remove a scanner. Is it the software thats playing up or the scanner itself?
Mar 23, 2009 | Syscan DocketPORT 465 Scanner
Scanner comes on automatically at computer startup
I would suspect that you have something else attached to your computer that is causing the scanner to react.
Disconnect the USB cable from the scanner and restart the computer. After the computer has fully restarted, connect the USB cable to the scanner. The scanner may initialize at this point. If after 30 seconds the scanner continues to cycle as you described, the that is an indication that there is something that is actively pinging the USB ports causing the scanner to react. If the scanner doesn't continue cycling, then reboot the computer and see if it does it again upon bootup.
Assuming that the scanner continues recycling:
Disconnect all USB devices (except the scanner) from the computer and then restart. If the problem goes away, then one of those devices is the culprit. Connect them one at a time, rebooting each time, to determine which devices is causing the problem. Once you determine the cause, then you'll know where to go for help.
Hope this helps.
Jun 11, 2008 | Canon CanoScan 3000F Flatbed Scanner
Epson V200 solution.
Do you hace a friend with a computer thsat you can install the scanner on to check where the fault lays.[computer/scanner]
Meanwhile do get on to Epson[ As the seller is out of business mare be lever to get some direct help here.
Jun 11, 2008 | Office Equipment & Supplies
Picture problem
is your computer connected to scanner?? if so remove the scanner and deactivate the scanner software in computer then the problem will not come.
Nov 18, 2007 | Canon PowerShot A95 Digital Camera
Problems with installing a plustek 7200i film scanner
Delete the software. restart computer Come off line. Disable the anti virus software and fire wall. Now reinstall the software. Check out that is runs before reinstating A/V and firewall.
Jul 24, 2007 | Plustek OpticFilm 7200i Film Scanner
Computers & Internet Logo
203 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
