Question about Xerox Workcentre 7545/P 7545P Color Advanced Multifunction Copier, Printer,
Drum installation xerox workcentre 7545
How do I install drum cartridge R1 R2 R3 R4
  • 2072 Answers
SOURCE: WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode
Posted on Mar 14, 2008
  • 2072 Answers
SOURCE: We have a Xerox Workcentre Pro575; it has an error
    1. Yes
    2. No
  3. Press [Stop] to return to the Standby Mode.
Posted on Nov 05, 2009
Testimonial: "Thanks very much, worked like a charm!"
SOURCE: Have Xerox workcentre 5225/5230 and keeps beeping
error 010-327
Posted on Jun 20, 2010
SOURCE: how to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
  • 117 Answers
SOURCE: how to install xerox workcentre
I am one of the technician trained and specialized in different computer  and printer manufacturer.
Here is one of the instruction on how to install your printer to windows 7 64 bit
-run the driver downloaded from the site, then select the location
http://www.support.xerox.com/support/workcentre-m118-m118i/downloads/enus.html?operatingSystem=win7x64&fileLanguage=en
-Go to Control panel
-choose devices and printers
-add a printer
-add a local printer
for Standard TCP/IP port has already been created on the computer, choose the port from the Use an Existing Port pull-down menu, next, and then skip to step 10.
For the port has not been created on the computer, choose the create new port button, choose standard TCP/IP from the Type of Port pull-down menu, click Next, and then continue with step 8.
-put the IP Address or hostname of the printer
-check if the query for printer is set to automatic, then next
-choose have disk
-choose browse, then select where you save the driver
-choose the required printer model
confirm the name of the printer
-choose do not share, then next
-choose finish
for more information visit:
http://www.support.xerox.com/support/workcentre-m118-m118i/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Contact number:
English 1-800-821-2797
Spanish 1-800-821-7726
Hours of Support - 24 x 7
I hope this will help a lot.
thank you for choosing Fixya
Posted on Feb 27, 2011
Values of the resistors
Resistors R1, R2, R3, and R4 are arranged in a circuit as shown in the figure above. The direction of positive currents I1, I2, I3, and I4 through the resistors are shown. (i.e., negative current values correspond to currents in the opposite direction to that shown above). The values for the resistors and the batteries in the circuit are: R1 = 100 ?, R2 = 200 ?, R3 = 30 ?, R4 = 400 ?, V1 = 4 V, and V2 = 12 V.
Nov 06, 2016 | Televison & Video
How to replace a R1 drum cartridge on a xerox 7545?
The entire 57 series from Xerox is one of the friendliest units for operators there are on today's market. To replace the drum module you simply need to unlock and drop the tray which is attached to it below the drum unit, then swing the locking arm to the unlock position and remove the old drum. All the drum replacement kits come with an instructional showing you how to remove the shipping material from the new drum and then simply replace drum into the copier and return locking arm and relock the lower tray to bottom of drum frame and shut the door. It's that easy.
ONE THING TO KEEP IN MIND: NEVER, and I mean NEVER touch your fingers or hands to the drum surface. The natural oils in your skin can cause damage to the drum surface. Be very careful when installing the drum to ensure that nothing touches the actual drum surface.
SECOND WARNING: Drums are LIGHT SENSITIVE! NEVER leave a drum exposed to office light or any other light source for more than 5 minutes. If you need to stop your replacement procedure, make sure you cover the drum with a dark black garbage bag or some other source that can completely stop the light from reaching the drum.
Mar 30, 2013 | Xerox WorkCentre 7525 7530 7535 7545 7556...
Kdc-bt30 turns on plays for a couple of mins then powers itself down and will not restart for a few mins
How many speakers did you conect to it? This looks like the autoprotection is turning off your system due to a overheating in the final transistors. When they cool down the system can be played again. Verify with the owner's manual what is the impedance of speaker accepted by the system's amplifier. Measure or calculate the resistance of your conected speakers on each channel. If they are conected serial the formula will be Rtotal=R1+R2+R3+R..... If connected in paralel Rtotal=R1*R2*R3*R..../R1+R2+R3+R... Where Rtotal is the value wich you have at head of the wires in the conector to the Playe/amplifier, and R1, R2, R3, R... the value of each speaker.
Jan 27, 2011 | Car Audio & Video
Problem with gopro hd
It means that your computer has limited resources to play up to R3 only. R4 HD is heavier to process that is why your computer freezes.
R4 and R5 needs higher processor speed, ram and the video card. Check and make sure that the 3 of them are compatible with each other and has outstanding bench mark.
For computer maximum performance use processor that has GPU.
Apr 07, 2010 | GoPro Digital Hero 3 Digital Camera
What is the Code for DVD-VR375?
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Mar 10, 2009 | Televison & Video
Making dvd player region free
2/Press menu button
3/Enter region code (See below for list) eg if your present region code is R1 enter 29334
6/Turn machine off
R1 - 29334
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Oct 16, 2008 | Televison & Video
Tht sims bustin out game playstation 2
Hi clinnane,
Try these>
During game-play press pause and enter the following codes. The Gnome cheat
Must be entered first for these cheats to work
Gnome Cheat:
R2, L1, R1, L2, Left, Circle
Note: If a cheat is not allowed a Gnome will appear on the Sim's property to
Signify this. You can click this Gnome for money.
Unlock All Socials:
L1, R1, Down, X, L3, R3
Unlock Team Photos:
L3, R3, R1, R2
Unlock All Skins:
L1, R2, X, Circle, Up, Down
Fill Motives:
L2, R1, Left, Circle, Up
Unlock All Locations:
R2, R3, L3, L2, R1, L1
Unlock All Objects:
L2, R2, UP, Triangle, L3 Happy gaming :)
Sep 23, 2008 | Sony PlayStation 2 Slimline Console
Need help
Hi
you havenot installed drum cartridge properly inside the machine or you have installed the drum cartridge of Xerox 5816/5821.
Hope you will do it.
Sep 18, 2008 | Xerox WorkCentre M118 Black and White...
Updating R1 on the ique
If you have r1 then you can not upgrade to the latest firmware unless you ugrade to r3 first. Search the internet for r2 and r3 upgrade or call garmin and have them send you a copy of r2 or r3.
Nov 16, 2007 | Garmin iQue 3600 GPS Receiver
Xerox Workcentre 7545/P 7545P Color Advanced Multifunction Copier, Printer, Logo
55 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
