Question about Samsung Refrigerators
Samsung icemaker in bottom spraying water into the ice
HVACRH20
  • 237 Answers
SOURCE: Water leaking from left side ice/water dispenser
If you describe a constant flow of water from the ice maker then the solenoid valve is either leaking by when it's upposed to be off or the motor module is stuck in the "fill" position. If it was stuck in fill you would be getting a LOT of water all the time so if you only have a trickle then the solenoid valve may be letting water leak by it. The diagram here shows the parts for a better idea of what you may need to look at (and where it's at). http://www.partselect.com/Schematics/Frigidaire/SZGBPCQH.gif
Posted on Jan 08, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: whirlpool fridge model WF-NL300 ice
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Posted on Feb 29, 2008
MNTECH
  • 1543 Answers
SOURCE: remove rerigerator door with icemaker water tube on bottom of door
If you want to replace just the water line going inside the door, you are out of luck. The water line is foamed in place inside the door and is not replaceable without replacing the entire freezer door. If you want to just remove the door, the water line disconnects by pushing the collar on the insta-push fitting toward the center of the fitting while pulling on the tube, all of which is located behind the toe kick plate near the bottom hinge of the freezer door. The same door is used on the PSS26MRSASS, PSS26MRSCSS, PSS26MRSDSS, and the PSS26MRSESS. It is part # WR78X11742 and runs about $500. (note: even if you don't like what you just read, accurate info on your repair question deserves a "FixYa" rating, not just a "helpful" or "thanks for trying".)
Posted on Sep 24, 2008
  • 11 Answers
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Samsung RFG298HDRS bottom ice maker stopped making ice.
Sounds line water line inside unit that runs to the bottom icemaker is frozen.
Nov 13, 2015 | Samsung Refrigerators
What is wrong when the icemaker leaks into the inside of the fridge
ok unplug frig open freezer door empty ice let freezer door stay open for a few hours ice has formed where the ice cube water comes into it. ice built up and water sprays every where but where it should
Aug 19, 2014 | Refrigerators
Ice making not making ice
Cycle the icemaker with the reset button. It is located on the bottom-front of the icemaker. Press and hold for 8 seconds to complete a cycle. You should hear an audible reset tone from the refer when complete. If it still doesn't work later in the day, it may need replaced. These units are well known for deplorable ice making capabilities. Samsung considers 60-72 cubes per day to be acceptable. I consider it an insult. For the icemaker reasons alone, I am looking into another (domestic) brand.
May 30, 2014 | Samsung RF265AA Bottom Freezer French Door...
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
Icemaker freezes up and deposits ice at the bottom of the compartment. My icemaker seems to freeze up and stop producing ice while dumping the water to the bottom of the freezer compartment where is...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze and can't go where it's supposed to. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
Water leaking from freezer compartment and ice maker not working properly
  • the water(in the bottom of the freezer) is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • and
  • the icemaker problem
  • it could be that the water valve is slowly leaking water into up to the icemaker and freezing before dripping out of the tube. then when the icemaker turns on the water to the icemaker it is partially blocked by the ice and sprays water all over instead of gently falling into the icemaker.
  • if this is the case then changing the water valve on the back of the machine and defrosting the fill tube behind the icemaker should fix this problem.
May 27, 2008 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
11 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
