Question about Xerox Workcentre 7545/P 7545P Color Advanced Multifunction Copier, Printer,
How to install drum cartridge R1 R2 R3 R4 IN xerox workcentre 7545
  • 2072 Answers
SOURCE: WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode
Posted on Mar 14, 2008
  • 19 Answers
SOURCE: Workcentre 24 Drum cartridge
Have you recently replaced the drum and if so does the machine not recognize the new one has been installed?
If this is the case then you should follow the steps below to replace the drum:
NOTE: Once the machine has instructed you to replace one of the drums (CMYK) then there is no way around but to replace the drum specified.
  1. Remove the new Drum Cartridge from its packaging and place it on a flat surface near the machine. Do not place the Drum Cartridge upright.
  2. Make sure the machine has stopped copying or printing, and then open the machine Front Door.
  3. Lift up on the lever marked 'A' located on the left front side of the Drum Cartridge.
  4. Pull down on the release handle to unlock the Drum Cartridge lock and access the four drum cartridges.
  5. Gently remove the Drum Cartridge (A1=Black, A2=Cyan, A3=Magenta, A4=Yellow) indicated on the Touch Screen, by grasping the light orange tab on the cartridge handle and pulling it straight out.
  6. Rest the new Drum Cartridge along with its black plastic protective shield into the cartridge slot. Make sure to load the cartridge in the direction of the arrow on the top of the shield and with the bottom of the shield resting on the release handle.
  7. Remove the tape from the top of the cartridge shield by pulling it off.
  8. Hold the Drum Cartridge shield and push the cartridge into the machine using the light orange tab.
  9. Remove the shield from the machine.
    NOTE: Make sure the cartridge guide is aligned inside the guide rail, if not reseat the cartridge. See the Related Items below for additional information.
  10. Lift up the release handle in the middle to lock the Drum Cartridge
  11. Push the lever marked 'A' handle latch down until it locks.
  12. Close the Front Door. If the Front Door is not completely closed a message will be displayed and the machine will not operate.
Posted on Nov 24, 2008
  • 2072 Answers
SOURCE: We have a Xerox Workcentre Pro575; it has an error
    1. Yes
    2. No
  3. Press [Stop] to return to the Standby Mode.
Posted on Nov 05, 2009
Testimonial: "Thanks very much, worked like a charm!"
SOURCE: Have Xerox workcentre 5225/5230 and keeps beeping
error 010-327
Posted on Jun 20, 2010
SOURCE: how to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
Values of the resistors
Resistors R1, R2, R3, and R4 are arranged in a circuit as shown in the figure above. The direction of positive currents I1, I2, I3, and I4 through the resistors are shown. (i.e., negative current values correspond to currents in the opposite direction to that shown above). The values for the resistors and the batteries in the circuit are: R1 = 100 ?, R2 = 200 ?, R3 = 30 ?, R4 = 400 ?, V1 = 4 V, and V2 = 12 V.
Nov 06, 2016 | Televison & Video
My xerox 7545 workcentre comes on, but it does not show the menu screen. it goes to fully on, but could not able to pick up menu screen.
Hello, The first thing you need to do it power down,unplug the workcentre and let sit for 2 mins. Plug back in and observe. If this doesn't work it will result in a call to your service provider and a field tech will have to trouble shoot the problem.
May 15, 2014 | Xerox WorkCentre 7545/P Copier
How to replace a R1 drum cartridge on a xerox 7545?
The entire 57 series from Xerox is one of the friendliest units for operators there are on today's market. To replace the drum module you simply need to unlock and drop the tray which is attached to it below the drum unit, then swing the locking arm to the unlock position and remove the old drum. All the drum replacement kits come with an instructional showing you how to remove the shipping material from the new drum and then simply replace drum into the copier and return locking arm and relock the lower tray to bottom of drum frame and shut the door. It's that easy.
ONE THING TO KEEP IN MIND: NEVER, and I mean NEVER touch your fingers or hands to the drum surface. The natural oils in your skin can cause damage to the drum surface. Be very careful when installing the drum to ensure that nothing touches the actual drum surface.
SECOND WARNING: Drums are LIGHT SENSITIVE! NEVER leave a drum exposed to office light or any other light source for more than 5 minutes. If you need to stop your replacement procedure, make sure you cover the drum with a dark black garbage bag or some other source that can completely stop the light from reaching the drum.
Mar 30, 2013 | Xerox WorkCentre 7525 7530 7535 7545 7556...
Kdc-bt30 turns on plays for a couple of mins then powers itself down and will not restart for a few mins
How many speakers did you conect to it? This looks like the autoprotection is turning off your system due to a overheating in the final transistors. When they cool down the system can be played again. Verify with the owner's manual what is the impedance of speaker accepted by the system's amplifier. Measure or calculate the resistance of your conected speakers on each channel. If they are conected serial the formula will be Rtotal=R1+R2+R3+R..... If connected in paralel Rtotal=R1*R2*R3*R..../R1+R2+R3+R... Where Rtotal is the value wich you have at head of the wires in the conector to the Playe/amplifier, and R1, R2, R3, R... the value of each speaker.
Jan 27, 2011 | Car Audio & Video
Problem with gopro hd
It means that your computer has limited resources to play up to R3 only. R4 HD is heavier to process that is why your computer freezes.
R4 and R5 needs higher processor speed, ram and the video card. Check and make sure that the 3 of them are compatible with each other and has outstanding bench mark.
For computer maximum performance use processor that has GPU.
Apr 07, 2010 | GoPro Digital Hero 3 Digital Camera
What is the Code for DVD-VR375?
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Mar 10, 2009 | Televison & Video
Making dvd player region free
2/Press menu button
3/Enter region code (See below for list) eg if your present region code is R1 enter 29334
6/Turn machine off
R1 - 29334
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Oct 16, 2008 | Televison & Video
Tht sims bustin out game playstation 2
Hi clinnane,
Try these>
During game-play press pause and enter the following codes. The Gnome cheat
Must be entered first for these cheats to work
Gnome Cheat:
R2, L1, R1, L2, Left, Circle
Note: If a cheat is not allowed a Gnome will appear on the Sim's property to
Signify this. You can click this Gnome for money.
Unlock All Socials:
L1, R1, Down, X, L3, R3
Unlock Team Photos:
L3, R3, R1, R2
Unlock All Skins:
L1, R2, X, Circle, Up, Down
Fill Motives:
L2, R1, Left, Circle, Up
Unlock All Locations:
R2, R3, L3, L2, R1, L1
Unlock All Objects:
L2, R2, UP, Triangle, L3 Happy gaming :)
Sep 23, 2008 | Sony PlayStation 2 Slimline Console
Updating R1 on the ique
If you have r1 then you can not upgrade to the latest firmware unless you ugrade to r3 first. Search the internet for r2 and r3 upgrade or call garmin and have them send you a copy of r2 or r3.
Nov 16, 2007 | Garmin iQue 3600 GPS Receiver
Xerox Workcentre 7545/P 7545P Color Advanced Multifunction Copier, Printer, Logo
325 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
