Question about Speed Queen Washing Machines
Speed queen washer model fw2182w will not agitate
  • 156 Answers
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
Posted on Feb 25, 2008
  • 14 Answers
SOURCE: I have a speed queen washer. Last wash my
the seal in the transmission is bad
Posted on Feb 22, 2009
  • 1294 Answers
SOURCE: I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Posted on Mar 06, 2009
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
Posted on Jan 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: Spots on white clothes
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How can i get the agitator off a speed queen modle number AWN412SP111TW01
If its a standard top loader there should be a cap you can pry off on top of agitator. Screw or bolt is under cap.
Nov 27, 2017 | Speed Queen Washing Machines
How do I remove the agitator on a speed queen washer model # aws17nw
It has a large nut under the cap on the top of the agitator, but it will be the devil to remove due to a tight fit and corrosion.
Sep 28, 2016 | Speed Queen Washing Machines
HOW DO I PULL AGITATOR ON A SPEED QUEEN WASHING MACHINE MODEL AWS76NW
down the center about 6 inches deep u have a 7/16 inch screw remove it then u can pull the first part of agitator, the second pc can be pulled out after but may not be that easy may have to pry it up
Mar 01, 2015 | Speed Queen AWS76NW Top Load Washer
How do i take agitator out of speed queen awn412 washer
To remove the agitator all that ya need to do is grab the bottom edges of it and pull it straight up and out..if locked onto a hub under it and is just held to that hub by several tabs
Gene
Aug 25, 2011 | Speed Queen AWN412 Top Load Washer
How to take out the agitator assembly in speed queen washing machine model awm693
That agtator fits and locks into place by a hub under it,by grabbing the outer edges of agitator and pulling straight up it should come off. Its not made to come off to easily and may need some muscle when pulling up.
Gene
Aug 17, 2011 | Speed Queen Washing Machines
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Dec 12, 2009 | Speed Queen AWS51NW Top Load Washer
Speed Queen doesn't agitate.
can i see solution that ziobob got on nov.08 2008
Nov 08, 2008 | Speed Queen AWS52NW Top Load Washer
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Speed queen top loader
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
T
Jul 27, 2008 | Speed Queen AWS44NW Top Load Washer
Washing Machines Logo
101 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
