Question about Frontgate Rowenta Pro Iron Steam Station - Frontgate
Rowenta pro iron steam station leaking from bottom of station
Water is leaking out of the bottom of the station - not the bottom of the iron. Is it overfilled?
Rowenta Pro Precision won't stop steaming until the tank runs dry.
Rowenta irons have a propensity for leaking. Most users do not add water to the tank but instead use a spritz bottle to dampen the fabric and then use the dry iron.
Jul 16, 2017 | Rowenta Irons
Rowenta DG8430 - steam coming from Cal Away plug?
Sorry but I cannot solve this problem. My problem with this iron was different.
Mar 05, 2015 | Rowenta DG8430 Pro Precision Steam Station
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
Rowenta microsteam 400
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
Jul 29, 2014 | Rowenta DW-8090 Pro Master SEWERS Iron...
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
We have a Rowenta Model DW 8080 steam iron. Even when the steaming feature is turned off, there is a water leak in the gap between the bottom plate and the upper part of the iron.
I too have this problem. Ihave bought so my of these irons. I wish so meone else could make something that could put the steam out that this do, that would last for more than a year!!!
Nov 18, 2010 | Rowenta Irons
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Water leaks from the bottom of the iron. Rowenta expert GV2380M steam iron
Yes it is from the bottom of the boiler from a small opening, I guess a vent. Thank you for the help.
Jul 06, 2008 | Rowenta DG-980 Iron
Frontgate Rowenta Pro Iron Steam Station - Frontgate Logo
54 people viewed this question
Top Frontgate Irons Experts
Are you a Frontgate Iron Expert? Answer questions, earn points and help others
