Toshiba satellite c650
Some my keys are doing funny things like the 5 turn of the number lock 0 adds dashes, z takes you to a new page,y just a letter before, and the arrow keys adds up when pressed.
    Habit-Forming:
  • 152 Answers
Press shift key five times continuously which popups up window for disabling strick key ,then disable it.
Posted on Feb 18, 2014
sparkysbox
  • 61 Answers
SOURCE: IBM ThinkPad laptop number/letter keys stuck
Try holidng the "Fn" key and the "NmLk" keys together and see if that helps.
Jeff
Posted on Mar 13, 2009
mikeleach
  • 48 Answers
SOURCE: problem with toshiba laptop keyboard pressing wrong extra keys
Take the keys off yor keyboard, clean and remove and dirt, replace keys and try again
hope this helps
Posted on Jun 07, 2009
  • 215 Answers
SOURCE: When I type letter keys, numbers come up with the letters
check your keyboard: T and 5 are relatively close to each other. Try to clean the area under keyboard buttons especially these two buttons. may be it can help you.
Posted on Sep 07, 2009
mariolands
  • 2296 Answers
SOURCE: i have toshiba satellite c650 laptop but laptopb
To reset the BIOS read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Dec 29, 2010
  • 226 Answers
SOURCE: The m and caps lock keys on my Toshiba satellite
Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
Posted on Apr 10, 2011
Toshiba satellite c655d-5332 keys problem
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Sep 23, 2012 | Toshiba NB205-N210 Netbook
Keyboard letters are numbers and numbers are letters
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Aug 26, 2012 | Amstron Toshiba Satellite M305-S49052...
How to restore factory setting of toshiba satellite pro c650.note that laptop bought without os preinstalled and oem os has been installed.pressing zero key does not work.i can not select bios option as my...
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jun 15, 2012 | Toshiba Satellite Pro C650-Z2510T Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Some of my keys are printing differently in my Toshiba Satellite A75 S209 Laptop
You need to turn off the Number Lock. Press the ScrLk/NumLk key it is located near the F11 key. When you turn off the number lock the NumLk LED light will also switch off and you will get letters instead of numbers.
Feb 20, 2012 | Toshiba Satellite A75-S209 Notebook
Sat pro c650 model psc09a-005019 Need copy of recovery disc for vista please can i download..
you should have a recovery partition on the drive itself when you turn on the computer immediatly hit f10 or f11 i cant remember if that doesnt boot into recovery. then you must shut down. hold the 0 (NUMBER) key then turn it on. keep holding it until it boots into the recovery partition. let me know if that helped. this model DOES have a recovery partion
Mar 20, 2011 | Toshiba Satellite Pro C650-Z2510T Notebook
Hello i am having trouble getting my computer
your product key should be 5 letters or numbers per block and there should be 5 blocks the product key is located under the laptop also make sure you type it EXACTLY as written some people get confused by 0=zero and O=the letter.
hope this helps.
Apr 25, 2010 | Toshiba Satellite Pro L300 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Sep 07, 2009 | Toshiba Satellite A105 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
David Payne
David Payne
