Question about Bay West Paper Silhouette Roll Towel Dispenser, 89500
How to install a bay west paper silhouette roll towel dispenser 89500
From which store i can get better Towel roll dispensers and Tissue roll dispensers in California?
Lollicupstore from you will get better Towel roll and Tissue roll dispensers in California.
You may visit - http://www.lollicupstore.com/
Or
Contact here:
Lollicup USA Inc.
6185 Kimball Ave, Chino, CA 91708
Phone: (626) 965-8882 or (800) 857-1988
Fax: (626) 965-8729
Jun 11, 2016 | Office Equipment & Supplies
Will not dispense towels. We pull the batteries out and put them back in. Sensor will pick up twice and dispense normally then it quits. replaced batteries....same thing happens. green and red lights...
Is there a reset button or a hole that requires a paper clip or nail? Sometimes reset means leaving the batteries out for 5-10 minutes. Have you contacted the manufacturer? - Especially if this a new purchase. Then I'd return it or exchange it.
Oct 17, 2013 | San Jamar T8400TBK - Compact Touchless...
What is more cost effective: hand dryers or paper towels?
We recently switched from paper towels to a hand dryer in my deli. Although the initial cost is definitely more for a hand dryer, I think that it will ultimately end up saving me money that I would be spending later on constantly having to buy more rolls of paper towels.
Apr 24, 2013 | Home
Ink levels show emptry.
Need one plastic plate that you don't care much about, or a plastic disposable plate.
Tear off one section from a paper towel roll and roll it up into about a 1-inch diameter roll.
Flatten the roll
Soak the flattened roll in warm water
Lay the flattened roll down on the plate
Place the nozzle area of the ink cartridge directly against the wet paper towel
Fold the flattened roll as needed to support the ink cartridge so it stands upright.
The trick here is to make sure the cartridge is supported upright so the nozzles come in full contact with the wet towel surface.
The wet towel acts as a wick to soften and draw out the ink.
After awhile, you shoudl see a kaleidoscope of colors on the paper towel. This indicates the nozzles have been opened up and the ink is flowing. Try to print and see what happens.
Repeat as needed.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Water dispenser drip
Use a cup instead of a paper towel. Empty as needed.
Jul 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Install towels (c-fold) into a Crown dispenser
use key open cover install 2 pks of c fold with cfold facing down and walla dispenser works
Jan 27, 2009 | Bobrick 262 C-Fold Paper Towel Dispenser,...
CANON BJC-85 DOES NOT PRINT
Try this to clean the print head;
Canon will hate me for this.
1. Remove ink cartridges.
2. Remove print head.
3. Go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head being careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air-dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 05, 2008 | Canon Office Equipment & Supplies
Colors not printing correctly
OK, Canon will hate me for this.
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
13. Start printing.
Jul 04, 2008 | Canon Office Equipment & Supplies
Canon mp950 printer unprnted streaks width wise - as if the paper is crolled too far for next line
I think your problem is blocked print head, try this.
OK, Canon will hate me for posting this.
13. Start printing.
Jul 01, 2008 | Office Equipment & Supplies
Bay West Paper Silhouette Roll Towel Dispenser, 89500 Logo
327 people viewed this question
Top Bay West Paper Home Experts
Donni Steen
Tom Chichester
Are you a Bay West Paper Home Expert? Answer questions, earn points and help others
