Question about CAS Thermal Printhead (AL11) for LP-1000 Series Label Printing Scale
CAS Thermal Printhead (AL11) for LP-1000 Series Label Printing Scale double print
Zero range error? the keypad is locked. what to do?
The zero range error means when the scale is switched on and the weight on the pan is above the zero range for the scale.Thanks
Sep 12, 2014 | CAS CL5000 Label Printing Computing Scale
Printing on edge
Your software label template does not match the size label your printing on. Make sure your label size IE: 2.25" x 1.25" matches the template size in the software, then perform this calibration:
TLP 2742 is printing blank labels
Apr 19, 2014 | Zebra Eltron LP 2824 Thermal Printer
DATAMAX E-4203 ONLY PRINTING HALF OF THE BARCODE
I doubt the sensors would have anything to do with only printing half a label. I'm not familiar with the E-class series of printers, but the common causes of that problem that I've seen before with the larger M & I class printers can be:
1) A piece of label or ribbon is stuck on the printhead.
2) The printhead is not seating properly on one side, causing the printhead to be too far away from the label & platen roller to apply enough pressure in order to print.
3) A printhead cable is not seated fully somewhere and not supplying the signals properly to that half.
4) The main logic board is bad.
5) The printhead is bad.
6) There is a software problem or label configuration setting that needs to be corrected that controls the print width.
Feb 26, 2014 | Datamax DMX E4203 Printer
How to calibrate?
just look up calibrate .there ar many ways to calibrate .
Feb 15, 2012 | CAS CL5000 Label Printing Computing Scale
I need to get manual/user's guide for scale CAS LP 1000 (need to re-program the scale...) Thanks!
you can find the user's manual on the CAS corp. site..here's the link...just scroll down to the downloads section on the left and u can download there http://www.cas-usa.com/lp1000n.html
Oct 18, 2010 | Microwave Ovens
MY ZEBRA LP 2844-Z IS PRINTING BLANK, WHAT COULD BE THE PROBLEM?
Since the LP2844 is a direct thermal printer, the first thing to check is to make sure you have direct thermal labels - regular label stock won't work. Just quickly scrape your thumbnail across the label, the friction will cause a black line if the label is direct thermal.
Aug 11, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra lp 2824 faded printing
Many factors affect print quality: Heat settings, speed setting and label face stock quality and type are a great place to start. How old is your printer? How many labels have been printed through it (there is an odometer that tells your this on the config label). Is the printhead dirty? Use > 90% isopropyl alcohol on a cotton ball or microfiber cloth to gently clean the printhead.
I would start by checking the heat and speed settings in the driver - crank up the darkness and crank down the speed a notch or two at a time until you get the print quality that you are looking for. If all of this fails, you may need a new printhead (not too easy to replace on this model). Printheads are made up of an array of resistors. These can loose their electrical resistance over time and require more energy (controlled by the darkness setting) to get the same results as a new printer. Printheads, like labels and car tires are considered a consumable commodity.
Jan 14, 2010 | Zebra Eltron LP 2824 Thermal Printer
LP2844 Printing light
Click start on your computer, go to control panel-printers and faxes folder. Highlight your Zebra printer and select 'printing preferences'. You are looking for a place to turn up the heat settings "Head Settings" or "Heat Settings". These get reset down to the lowest setting when you continually open the cover without turning the printer off first....exposing the printhead to light.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
My lp 2844 will not print
Firstly is your label Thermal Direct?(DT)
To test quickly score your fingernail across the surface of the label, if it leaves a black mark then it is DT
If there is no mark then it is probablly Thermal Transfer(TT) and requires a ribbon, which you cannot use on the LP 2844, only on the TLP2844.
If you have DT labels then go into the printer driver via Printers & Faxes and the Printing preferences and change the darkness to level 7.
Try printing again.
If it works then cahnge the darkness again until you get a satisfactory print darkensss.
If it still does not print then change the darkness to maximum, does it print?
If not then I think you have a duff printer, return it to the company that supplied it for repair.
Any problems contact Lancer labels
Apr 05, 2009 | Zebra LP 2844-Z Thermal Label Printer
CAS Thermal Printhead (AL11) for LP-1000 Series Label Printing Scale Logo
Top CAS Office Equipment & Supplies Experts
jasbo
jasbo
Are you a CAS Office Equipment and Supply Expert? Answer questions, earn points and help others
