Question about Mongoose MGX Maxim Dual Suspension Mountain Bicycle
Rear wheel wobbles - Mongoose MGX Maxim Dual Suspension Mountain Bicycle
    Problem Solver:
  • 7 Answers
To me it sounds like a loose hub, can be done with two wrenches called cone wrenches.
Posted on Apr 03, 2015
  • 33 Answers
It sounds like your spokes are loose. Unless you have experience in tightening spokes you need to take the bike or wheel to a dealer. It is very easy to get the wheel wrapped if you have never done this before.
Posted on Apr 02, 2015
I have a wobbling back end seat leon 1.9 tdi 2008 plate
wobbling from the rear end can be from worn suspension rubbers in the control arms. Normally it is from belt separation in the tyres and bulges in the side walls
I take it that it is a front wheel drive with no diff action at the rear.
another point may be that the rear brakes are grabbing ( out of round drums or warped discs) that is causing the vehicle to react as if the rear is loose.
Feb 10, 2015 | Seat Leon Cars & Trucks
Rear wheel is wobbling
I wouldn't drive it because the wheel could come off if the bearings go out, and they might. Have it towed to a shop and have a mechanic look at it. This condition is DANGEROUS.
Mar 30, 2014 | 2000 Mercury Grand Marquis
The driver rear tire wables when driving
I assume that the wobble is side to side and not up and down. The most benign cause of wheel wobble is a bent tire rim; but since you've tried another wheel and still get the wobble, the cause could be a bent housing, bad bearing, a number of things. In any case, if you don't get it fixed, a castastrophic failure is likely to happen. The rear axle is semi-floating; the axle and wheel are held on only by the pressed-on bearing and a small circlip. See a mechanic ASAP.
Jan 07, 2012 | 1994 Isuzu Rodeo
My rear right side tire is wobbling on my cheverlote cavalier?
are the lug nuts tight?
If so you may want to remove the wheel to inspect more thoroughly as that is serious - you may have a possible broken lug bolt - hard to say more without more details.
: Possible bent rim?
Loose half shaft (depending on if front or rear?)
Bearing on the spindle could be shot if on the rear..
best regards
Ck
Mar 14, 2011 | 2000 Chevrolet Cavalier
The rear end of my car is wobbleing anytime i go over 15 mph
check wheel lug nuts to insure both rear wheels are tight. you may have a bad tire on one side or other,have someone watch car from rear when you're driving it to pinpoint the wheel thats wobbling. that will narrow the search.a warped rim may be the problem,if so install your spare and look at used parts places for another rim and tire to install.hope this helps and thank you for choosing fixya.com
Jan 04, 2011 | 1999 Plymouth Breeze
The rear tire is on tight but it wobbles and shakes the whole car when i drive it. it has good tires on it.
3 possible answers. 1 the rim is bent 2 . unbalanced tire 3. wheel bearing needs replacement
Jan 03, 2011 | 2004 Pontiac Grand Prix
I have a pougeot 206 gti and it is knocking at rear on bumpy roads also found it to snake around fast bends, seams to be play on rear wheel
It could be wheel bearings, jack the rear wheel up and grab the top and bottom, wobble it, and if it wobbles alot, then the bearing has gone, or you may just need to grease them up.
It could also be susoension bushes( rubber or nylon inserts on the bolt points ) again, jack the rear up and look at the bolts that hold the suspension on and wobble the components to check if they move too easily( you will always have a small amount of freeplay ) REMEMBER TO USE AXLE STANDS AND CHOCK THE FRONT WHEELS WHEN WORKING UNDER A CAR, EVEN WHEN ON AXLE STANDS you don't want a tonne of steel pinning you down.
Sep 26, 2009 | Peugeot 505 Cars & Trucks
96 saturn right rear tie rod bent bad
i would have the shock/spring checked out as I'm sure that's whacked. and potentially the wheel bearing causing the wobble. the rim / tire may also have damage causing a wobble. the wobble could also be caused by a simple wheel balance weight having been knocked off from the accident...have the tire balanced at a shop....2nd jack up the side. swap the front wheel and put it in the rear and spin it...this will tell you if there is more structural damage to the rear suspension. being the above listed. As far as the ball joints, usually they will be fine or snap.
Mar 15, 2009 | 1996 Saturn SL
Left rear wheel wobbles
put on your spare doughnut tire and see if it's bent to .. if it is then you bent the axle not the rim.
Jan 06, 2009 | 1993 Nissan Altima
2005 Ford Explorer Rear Wheel
sounds like your rear wheel bearing has collapsed, which in summery is a very bad thing i would not get your male friend to replace this as it is a very big job witch requires specialty tool eg. 10 tone press.
also if the bearing is replaced wrong it can course feather problems at the worst i will loss the rear wheel at the best the abs may stop working.
your best bet is to have the car towed to a ford dealer our to a differential specialist the latter may be a cheaper option.
full credit to you for jacking up your car and checking it that is more then most people do these days
good luck and let me no how you go
Dec 19, 2008 | 2005 Ford Explorer
Mongoose MGX Maxim Dual Suspension Mountain Bicycle Logo
129 people viewed this question
Top Mongoose Cycling Experts
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Roger Paull III
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
