Question about Dell XPS Computers & Internet
Replace Capacitor Dell XPS
420
  • 3 Answers
SOURCE: xps 420 keeps freezing or going to blue screen
change/clean the cpu fan or try to reduce heat arround the processor
Posted on Jun 24, 2009
joecoolvette
  • 5660 Answers
SOURCE: My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Posted on Jan 04, 2010
  • 3940 Answers
SOURCE: dell xps 420, won't finish loading bios boot
see if this info helps narrow down the failure
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Posted on Apr 03, 2010
  • 78 Answers
SOURCE: my dell xps 420 will not power on. power light
Hi
If your system's power light blinks amber, it means the computer is receiving electrical power, but an internal power problem might exist.
Do the following to tackle this issue:
  • If applicable, make sure that the voltage selection switch which is at the rear of your system matches AC power in your area.
  • Ensure that the power cable is securely connected to system board.
Here are links with pictures to assist you in opening the system and reconnecting the internal cables.
Please follow safety instructions before you perform these tasks. Here is a link, which gives you complete safety instruction.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372453
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372490
Next is to see the system board design. Here is the link.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1402834
and if you wish to research a bit more here is the link,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1076480
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1097292
Here you will find complete manuals for further research
If this does not resolve the issue, then the motherboard or processor is faulty and you need to get it replaced, so if your system is within warranty why pay extra, get it replaced from Dell. Else contact a local tech and he'll help you out.
Please rate as per the assistance level. Thanks :)
Posted on May 22, 2010
Testimonial: "Very detailed and organized. Very helpful."
ginoman
  • 9 Answers
SOURCE: When i try boot my dell xps 420 it states that
A boot device stores your operating system (i.e. Windows), and is usually your hard drive, but can be any storage medium such as a floppy, usb flash drive, or even a cd rom. When you turn your computer on, your motherboard looks for your OS on any of the storage devices specified in your bios, in the order specified to look first (Ex. Boot order: 1. CD-Rom, 2. Floppy, 3. Hard Drive, 4. Network). Your Dell is telling you that it can't find Windows on any of these devices. Most likely cause is that your hard drive stopped working, your Windows boot.ini file became corrupted, or you have a USB device plugged into your computer, and it needs to be unplugged before turning on your computer.
Posted on Oct 02, 2010
Xps 420 fan
as long as it has the same connector than yes. fans are usually the same when it comes to personal computers
Mar 05, 2014 | Computers & Internet
Xps 420 start up problems error codes 1 and 3
Dean Fowler,
The 1-3 error code that you are saying that your computer is making represents a Video Memory Test failure. Try reseatting the video card in your computer or replace the video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 29, 2013 | Dell XPS 420 Desktop Computer
I have a dell xps that came with a wireless/bluetooth keyboard with mouse pad and i have another dell xps 420 that i'd like to use the wireless keyboard on...they are both dell xps's and both
Wireless/Bluetooth keyboards and mice can only be used with one device at a time it is like a bluetooth headset once it is paired with a phone it will 99.99% of the time only work with that phone and that phone only, Wireless keyboards and mice are setup on the same principal once they are paired up with 1 PC to use on another PC you have to remove the pairing. The worst case scenario is that the second PC's Wireless/Bluetooth has failed. I hope this helps.
Sep 03, 2012 | Dell XPS 420 PC Desktop
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
Jul 03, 2012 | Dell XPS 420 PC Desktop
My Dell XPS 420 will not turn on. Power light shows a steady blue color. No diagnostic lights show up.
The RAM maybe faulty.
Try resetting the RAM modules to make sure it is seated correctly in the memory slot.
If the computer still does not boot up then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them tested. If faulty then replace the RAM.
Feb 25, 2012 | Dell XPS 420 PC Desktop
Connect midi to dell xps 420
You can use Midi to USB adapters.
Here: .MIDI Interfaces
Feb 06, 2012 | Dell XPS 420 PC Desktop
I have Dell destop model XPS-420 my computer is not getting on NO FAN and no noise please advise me what should I have to do
hi
are you saying the fan is not working ? if that's the case, you need to replace the fan.
get the service tag # located on back of your desktop PC, go to this link below, place service tag in appropriate box . it will give you part numbers for the peripherals of this computer. locate the fan and purchase replacement.this is all you have to do. DO NOT TURN ON THE COMPUTER UNTIL THIS FAN IS REPLACED, or you will damage the mainboard and/or CPU.
http://search.dell.com/results.aspx?smh=sup&c=us&l=en&s=dfh&k=XPS-420%20&cat=sup
Nov 14, 2010 | Dell XPS 420 PC Desktop
Dell xps 420, won't finish loading bios boot screen, freezes and gives steady fast beep,cant get into safe mode, no clue what to try
Apr 03, 2010 | Dell XPS 420 PC Desktop
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
