Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
I need to replace the belt
Hi I need to look inside to see why the brush is not turning around. I think it could be the belt, but first i need to look inside. I have removed all of the screws from the underside of the vacuum, but it does not seem to be the right way to get into the brush mechanism.
  • 55 Answers
Maybe the belt slip off or look on the brush`s for where the belt goes, should be on one side or the other.
Posted on Feb 15, 2014
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
reddevil6
  • 1673 Answers
SOURCE: ken 116 31912100
No belt, this is direct drive, the motor is part of the brush roll. If you go to sears.com, click on parts, put in you rmodel number, it starts with 116.*********. It will bring up a parts list along with a picture breakdown for you to look at, and you can order parts there also. You might also check where the hose goes into, some of these have a switch there, when you push the hose in it hits an actuator that engages the switch. This actuator breaks and then the brush roll won't turn because it can't engage the switch.
Posted on May 08, 2008
  • 22 Answers
SOURCE: Kenmore vacuum - no suction, brush wont turn
sounds like the vacuum is clogged and putting too much stain on the agitator, so I would clean out the entire passage way for the vacuum and replace the agitator belt, you must clean out all the hoses it is clogged somewhere
Posted on Feb 10, 2009
  • 134 Answers
SOURCE: Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Posted on Mar 12, 2009
  • 12 Answers
SOURCE: Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Posted on Sep 14, 2009
My dyson animal is working but the brushes will not turn around so it only has suction any ideas
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 29, 2016 | Dyson Vacuums
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
https://www.thinkcrucial.com/search?type=product&q=dc07
Ava B.
Dec 09, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt is still attached, but brush will not turn.
If the motor runs but the brushes aren't turning, there are several possible reasons:
1. There is something trapped in or around the brush bar. Lie the vacuum on one side and make sure you can turn the brushes by hand. They should give some resistance when turning by hand, but the should turn.
2. The belt is worn/stretched and is slipping. This is often accompanied by the smell of burning rubber.
3. The belt is broken. It may still look attached to attached to the brushbar but it could be broken inside.
4. The brushbar isn't inserted correctly.
REMEDY: Please follow these simple instructions to determine the cause of the fault.
Disconnect the power and allow to cool for at least an hour if you have been using it
1. Sit on a chair, turn the vacuum upside down and hold it between your knees:
2. Undo the 3 fasteners at the positions shown in the picture below on the underside of the dyson (use a coin). Pivot the back edge of the sole plate upwards and lift off the sole plate which covers the brush bar:
3. Check for any debris around the brushes that may be stopping it from turning
4. Check that the brushbar is correctly inserted:
5. Check that the belt is intact and tight and correctly looped over the motor spindle:
If the belt is intact and tight, the brushbar turns freely and is correctly inserted and the motor runs, then your belt is probably worn/stretched and needs replacing.
All of the other possible faults can be fixed once the sole plate is removed (Step 2). Remove any debris from the brushbar, make sure it is correctly inserted, and make sure the belt is correctly looped over both the motor spindle and brushbar.
If you need to replace the belt, please see my other post for replacing the belt on a DC07
http://www.fixya.com/support/t7232645-fit_new_drive_belt
If you have done all of the above and there is still no obvious reason why the brushbar isn't turning, please post back for further assistance.
Hope this helps.
Regards,
BElectric.
Dec 14, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush roller not spinning properly
Yes there is a belt and yes it is easy to replace it. There are a couple of screws that hold the cover on and then you can just lift out the brush, get the new belt around the motor shaft and then around the brush. The new belt will need to be stretched tight but that is a good thing....
new belts can be purchased at many grocery stores or vacuum repair shops...
heatman101
Apr 29, 2010 | Hoover Commercial Windtunnel C1705-900...
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hi,My agitator brush won't run on my hoover S3590, I changed the belt, that didn't work. I don't see a possible cause in my book except replacing the belt. I think there could be a short, the brush will...
Hi Bobbie Take apart the electro floor head if you can and inspect inside - it may well be that there's clogged dust preventing the brush from turning and also check both sides of the actual beater bar as thread and tangled hair can often lead to a brush turning every so often.
Mar 03, 2009 | Hoover S3590 Bagged Canister Vacuum
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
No action
I had the same problem with the belt breaking and the roller not spinning. I read about giving the roller a couple of revolutions to seat the belt, so I put another new belt on. It still didn't spin. I realized it was the end cap that was not spinning so I took off the roller and gently pried off the end cap and there was an enormous amount of thread spun around inside of the small area. I had to keep digging it out with tweezers. Quite unbelievable. I also found that when it spits out instead of sucking up, it needs to be cleaned. Check all areas, especially the part that is round that you have to twist open. (Inside, behind the foam filter and UP).
Jul 13, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka the boss the brush wont go around
Hey there scrappy13, I would suggest you unplug the unit, turn it upside down and remove the bottom plate uncovering the brush assembly. Inside there should be a belt which drives the spinner brush. If that is in tact, then the brush itself may have been unseated when you pulled the rug out. It should be obvious to find the correct placement. Reseat, ensuring the belt is attached properly to the motor as well as the brush. If the belt has broken, a replacement is available at a registered repair facility. Good Luck!
Jan 29, 2008 | Vacuums
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
22 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
