Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES3 Error code 41. Controls cycle on and off randomly.
The control panel on our washer will turn on and then go off on it's own about 20-30 secs later. Then it will come back on and display a backwards L and then go back to normal and then repeat. Have tried unplugging machine and plugging back in but it still does it.
  • Official Brand Answer
  • 4,342 Answers
Hello Scott, thank you for allowing me to assist you!
Based on the symptoms you are describing and if you are receiving an error code E41, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power again to your appliance for about ten minutes. If the error persists, it could either be the door switch assembly or the main control board in your appliance. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Best regards!
Posted on Feb 20, 2014
Master_Tech
  • 770 Answers
SOURCE: washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
Posted on Apr 01, 2008
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Posted on Aug 19, 2008
SOURCE: Affinity washer displays ERR. PAU and 56
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
SOURCE: Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
How do I find the control panel that controls the pump motor? Due to error code E23?
Frigidaire GLTF2940FS1 washer Error Code E23 ...
www.shopyourway.com > Manage My Life > Questions
Sep 13, 2013 - My washer stopped mid-cycle and emitted a burnt odor. Troubleshooting shows error code 23. I pulled the connector off the pump and have ...
Kenmore Washer (48112) E23 error code ' ShopYourWay
Get shopping advice from experts, friends and the community! Hey all, I have a Kenmore front load washer model #48112. When I hit the start button the NO ...
Oct 23, 2015 | Washing Machines
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
What is error code 41
Good Afternoon Donna,
I see that you are wondering what an error code 41 is on your Frigidaire washer, model# GLTF2940ES. Error code 41 means the control board thinks the door switch is open. You will want to make sure the door is closed. Reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker. When you restore power select any cycle and start it. If you are still receiving an error code 41, I suggest contacting your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 27, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washer ON and OFF continuously
Error code EB1 is "Incoming power frequency out of limits." Here is a link to various error codes.
http://www.partselect.com/Blog/archive/2008/09/16/frigidaire-appliance-fault-codes.aspx
Jul 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
My washer wont spin
Frigidaire front loader model # GLTF2940ES3.
Cycle ended prior to spin segment. Checked error code history to find E47 fault. Troubleshot per manual. Found that the "PTC one-spot check" read ~1582ohms. Although the book indicates that this is sufficient and recommends (rather tells) you to replace the control board we were still skeptical seeing as this is a ONE POINT check on a device that is non-linear. We went with the lesser of two evils. Purchased and replaced a new door lock. Works again! Phew, that could have been costly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
132 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
