Question about Duracraft Humidifiers
Dehumidifier is leaking water from under the unit , water not all being collected
2 Suggested Answers
  • 2468 Answers
SOURCE: Dehumidifier not collecting water
do the lines from the compressor to the evaporator freeze up or ice up anywhere,if so it could be low on refrigerant,also check the start capacitor in the compressor power circuit,if its bad the compressor won't run
Posted on Apr 04, 2010
Humidifier blows cool air only not collecting water
a humidifier doesnt collect water only disperses it. a dehumidifier collects water
Jul 05, 2017 | Humidifiers
Dehumidifer runs, but does not collect water. Just started this recently. We use it in the basement. Not too old. It's a Whirlpool Accudry.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 07, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
The water doesn't come down when it's turned on.
heatman101
Jul 31, 2011 | Humidifiers
The unit is leaking water, but not from the collection bucket. The unit is in the basement, has worked well for many years, but has never been serviced or cleaned.
More than likely, the drain tube or hole that delivers the water into the collection bucket is clogged. To clear the clog: First turn the unit OFF and unplug it from the wall outlet. Use an 18 -20" long plastic Zip Tie, that will fit into the drain tube or hole. DO NOT use a wire coat hanger for this. Carefully insert the Zip Tie into the hole or tube and gingerly work it in until you reach the bend of the tube. This is where it gets a little tricky, because you must get past that bend, to be effective. Once the Zip Tie has reached it's limited reach or it has bottomed out. Slowly pull it back out, while rotating it. This will remove any clogs, so be prepared for water to follow.
Hope this helps you solve that leaky situation. Please let me know.
May 06, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
The humidifier appears to be working (with sound ) but is not collecting any water-cleaned the filter and still the same -the lit up area where it usually has the numbers is sitting at P2- I have lost the...
Alison -
A humidifier will not collect any water. A humidifier has a tank that you fill with water. The water is released / forced into dry air to make it moist, usually by a fan or ultrasonic method.
A dehumidifier has an empty tank that gets filled by the appliance extracting moisture from the air. The tank will have to be manually emptied periodically, otherwise the safety / water level switch will shut the unit off so that the tank doesn't over flow.
I suspect that you meant to say dehumidifier.. and if so, please provide the manufacturer's name and model. The "P2" indication will be difficult to interpret without knowing the manufacturer's info.
Nov 22, 2010 | Humidifiers
Whirlpool accudry dehumidifier doesnt work, the fan runs, but i think theres something wrong with the compressor, it clicks (on and off it seems) every bout 5 seconds. what could the problem be?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Sep 14, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Apr 04, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
May 20, 2009 | Whirlpool AD40U Humidifier
Humidifiers Logo
55 people viewed this question
Top Duracraft Humidifiers Experts
Paul Carew
Dennis
Are you a Duracraft Humidifier Expert? Answer questions, earn points and help others
