Question about Tecumseh 5hp Engine Snow King Mtd Blowers Lh195sp67517
Snow blower ariens 1328 pro manuel
Belt replacement
Ariens 1336 Pro, the problem is that it will just stop dead. Engine runs strong, blower keeps discharging but the drive just stops. Wont go forward or reverse. After a little time it will take off.
what exactly is it and what are you doing . sounds like a lawn tractor with snow blower and tranny fluid is not being pumped thru because of too cold . Am I close ??
Dec 15, 2017 | Cars & Trucks
I have an Ariens 921037 snow blower. The auger still turns when not engaged.It's very slow but it still turns. How do I adjust that?
find a youtube video about adjusting the brake on it. thats what it is. is it possible your belts are too tight when not engaged? check that first. you can download the owners manuals from ariens website too
Nov 26, 2017 | Ariens Garden
My ariens 8524 doesn't blow snow very good,whats wrong? sheir pins are good and i put a new auger belt on it
Does your engine rev up the way it should. You can't blow snow very well if you engine is at half speed.
Dec 22, 2016 | Garden
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
Need belt size for poulan pro 96194007 snow blower
Is there a part number on the belt itself? Try googling the model number and putting in belt.
Mar 01, 2014 | Poulan Pro 24" 2Stage Snow Blower Electric...
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
The blower won't throw snow - especially heavy snow. Auger and impeller turn but bog down. Trying to replace belts, but there are no numbers or sizes on them. Are these generally available (say at a...
If the belts are intact, then NAPA or a hardware store should be able to replace them. If they are shredded, then you should order them from Ariens. Good luck!
Feb 01, 2011 | Garden
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Tecumseh 5hp  Engine Snow King Mtd Blowers Lh195sp67517 Logo
62 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
