Question about ASUS R503u-rh21
How to set to factory settings? - ASUS R503u-rh21
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Mfc7340 where is factory reset
Restoring all settings to the factory settings, you can restore all the settings you have changed to the factory settings. These settings will stay until you change them again.1 Press Print Setting.2 Press a or b to display Factory Reset.3 Press Factory Reset. 4Press Yes to confirm.5 Press Stop/Exit.
Jun 10, 2014 | Office Equipment & Supplies
Factory settings
Yes, the factory default means the settings that came when you first connected the printer.
May 06, 2013 | Office Equipment & Supplies
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
My vizio has input locked
Hello
Reset the device to its factory settings. To reset it to factory settings, enter "Setup", select 'Reset All Settings", press [=>] button to reset the TV to its factory settings. All parameters, except the parential lock will be reset to it original factory settings. If you for got the pass code, just enter its factory reset passcode [0000]; Eventhough the set will report this to be wrong passcode, input [0000] once again. This will unlock the passcode, and you have to set a new passcode. OK.
Sep 02, 2011 | Vizio VX20L 20 in. LCD TV
I want the 'restore factory settings' code for tecno 0707
i need a factory setting code for my Tecno life
Mar 01, 2011 | Cell Phones
CODE FOR FACTORY SETTING IT WILL RENEW THE SYSTEM? what factory setting mean?
factory setting code is 12345. Resetting a device to factory settings means it will then be in the same condition as when it left the factory.
Jan 06, 2011 | Nokia 5800 XpressMusic Smartphone
Factory settings ws55908
Normal factory settings are for normal video and audio. Convergence factory setting will default all convergence setting requiring a full alignment of which I would not recommend. Factory settings in the service mode will change the geometry, gray scale, and others, that's another one I would not recommend. Tell me why your asking, and the problem your having?
Oct 24, 2009 | Mitsubishi Televison & Video
I cannot restore the factory setting for my nokia 6030 mobile
1 way: Select Menu > Settings > Restore factory settings
or:
*#7780# reset to factory settings.
Jul 31, 2009 | Computers & Internet
ASUS R503u-rh21 Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
