Question about Juliska Home
One of our Emerson dinner plates has some visible etching that is appearing on the white part of the plate. We have had these since Dec, 2013.
Is this covered via warranty?
SOURCE: how to remove face plate
how to remove a contact person in "my fave". motorola zoom 4x
Posted on Aug 01, 2008
buffalonyman
  • 1865 Answers
SOURCE: top plate does not get hot, bottom plate is ok
The element could have a very fine crack in it, not readily visible. You must use a voltmeter to test if the element is getting power when the switch is turned on. If it is getting power, then the element is bad. If no power, then test the switch to see if it is sending power when turned on.
Posted on Jul 07, 2009
  • 4 Answers
SOURCE: Emerson MW8999SB 900-Watt Microwave replacement plate
From what I could find, it should be 10 1/2 inches in overall diameter.
meowpfttpftt
Posted on Mar 31, 2010
  • 150 Answers
SOURCE: John deere 68 riding mower steering column won't
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Posted on Sep 27, 2010
Testimonial: "sounds good will try to fix it thx"
SOURCE: Hampton Bay 52 white ceiling fan model 5745 A
which remote control do I need for Hampton Bay model 5745A
Posted on Sep 23, 2011
What are the different type of plate shapes?
Rim-shaped plates originated in Europe. In the West, food portions are cut into bite-size pieces at the table, and the rim-shaped plate is made with a well that collects the juices that flow from the food.
Coupe-shaped plates have no rim and accommodate the way food is cooked and served in the East. In the East food is cut into bite-size pieces in the kitchen and cooked quickly over high heat.
To allow space for the courses on one plate, the diameter of the coupe-shaped dinner plate is approximately 1 inch larger than that of the rim-shaped dinner plate.
-http://www.etiquettescholar.com
May 06, 2013 | Home
Tings not holding dinner plates
please replace the parts go www.repairclinic.comGod bless you
Apr 05, 2013 | Dishwashers
Dinner plate stops arm rotating, plates must be able to go in. why is the arm hitting the dinner plate.surely you must be able to wash your dinner plates in there, from tray to arm is 250cm.
on the topshelf of the dishwasher there are 2 lots of slide wheels . these are to set the shelf at different heights they should be on the lowest wheels to give you the maximum distance between the bottom tray and the spinning arm
Jul 30, 2011 | Dishwashers
My standard size dinner plates are too tall, the rotating part is catching the plates
Some machines have height adjustable top shelf.
Should be couple of clips on side of rack to raise / lower.
Other than that you will have to get smaller dinner plates.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Do I need to clean the filter behind the lower front panel? I removed the panel but nothing in the owners manual that describes it. I heard that you need to do this every year or so for general...
Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. The kick plate is the lower outside cover of the washing machine.
Place a small bucket under the white hose. Remove the cap on the white hose by untwisting it. Allow any remaining water in the hose to drain into the small bucket. There shouldn't be much water, but there can be some.
Look inside the white hose. Remove any visible obstructions or lint.
Look inside the hose cap. This is where the lint filter is. Remove any visible lint with your fingers. Rinse the hose cap under warm water to remove any remaining lint.
Twist the cap back onto the white hose. Put the kick plate back in place. Screw back on.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water spinner hits dinner plates and cannot turn. i can see no way to adjust the height...my dinner plates are average size i didnt have a problem with my other dishwasher.
Check the side left & right side. There should be an adjustment. Pull the rack and observe. you might have to select the lower rails.
Refer your user manual.
May 24, 2010 | Dishwashers
Hi, I have a Westinghouse ADP6000WH dishwasher and...
You have to check the slider rails. If you watch the there be a different slot. You can remove and place it in that area.
Otherwise remove the top rack and run as special cycle for this dishes alone!!!
May 21, 2010 | Dishwashers
Normal dinner plates hit the top washer arm in Bosch dishwasher
TRY TO ADJUST THE FINS IN THE BASKET TO SIZE PLATES . THE MANUALLY RECOMMENDS HOE TOLOAD DISHES.
Feb 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Top plate does not get hot, bottom plate is ok
Jul 07, 2009 | Cuisinart GR-4 Griddler
Home Logo
207 people viewed this question
Top Juliska Home Experts
john h
Tom Chichester
Are you a Juliska Home Expert? Answer questions, earn points and help others
