Question about Bushnell Optics
Bushnell rangefinder mode button is stuck in down position and the only display is generic
Mode button seems stuck so that pushing the power button results in a "test pattern" screen. Can I fix this myself?
SOURCE: my washing machine is stuck on TEST
I have just experienced this problem and husband has been able to sort it. You just press On/Off and Start/Cancel buttons at the same time for a couple of seconds. You will have sorted this by now but someone may find this helpful.
Posted on Jan 29, 2007
SOURCE: bushnell 400 rangefinder won't show yardage
does anyone have the same problem? How do you fix it?
Posted on Nov 30, 2007
SOURCE: No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
Posted on Oct 22, 2008
SOURCE: Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Posted on Nov 06, 2008
  • 133 Answers
SOURCE: Bushnell Pinseeker 1500 Laser Rangefinder
All these units need an alignment....Vibration and dropping are slow death to Pinseekers.
Posted on Apr 24, 2009
WHY DOES IMAGE SHOW (FLAG) LEFT SIDE AND FOLLOWING BOTTOM OF VIEWER: 1 888 YM +18 D 888 BATTERY CHECKS OK SAME IMAGE APPEARS WHEN TOP BUTTON IS DEPRESSED.
Mine showed the same, found to be the mode button stuck in, removed button and used cotton bud with alcohol rub into the rubber seal, gave it a good clean and now as good as new. Hope this helps.
Nov 05, 2015 | Bushnell Tour V2 Pinseeker Laser...
Bushnell range finder #200800 dated 5/97
http://bushnell.com/manuals/rangefinders/20-0880_YP_Compact_800.pdf
Jun 28, 2010 | Bushnell Yardage Pro 800 Compact...
I can't get it to bow or rifle mode
Look on the back of the rangefinder......Its a very small strip that has the model number, serial number, and date of manufacture. If it sez.....20-1932 you have a "bow and rifle" rangefinder.....!!!! If it doesn't have model number 201932. You don't have that capability. Read your manual, check the unit for the model type.
Part 2: Try holding down the "FIRE BUTTON" for more than 5 seconds....see if the the "setup" comes across the display screen........(read the manual) The unit should have came with a ballistic disk. If you don't have one call Bushnell and get one. (800.423.3537) It has a lot of good info on it.
Good Luck to you David!!!
mr tech geek
dont forget to rate....
Jul 16, 2009 | Bushnell SCOUT 1000 Rangefinder
I have a Bushnell Medalist Pinseeker golf laser rangefinder. I recently replaced the battery with a 9V Duracell Alkaline, and now the Pinseeker mode is not working (it will not sight different targets) and...
The "Pinseeker" mode is a automatic mode Sometimes it uses it, somtimes it doesn't. It is designed to recognize a vertical shaft. (Pin) Now IF you hold the power button down....you can see if all of the LCD segments are burning. If the segments fade out later in the game.... (bad LCD) Make sure the Pinseeker mode it on...(flag symbol on the left) Hit the button on the side if you need to. IF it still doesn't lock on to pins, it needs an alignment.
MTG
Jun 23, 2009 | Bushnell Golf Medalist BUU0055 Rangefinder
Recently purchased ypc 600, no manual, on screen read-out is in meters. can I switch this to yards?
Two buttons on the top. The big one is the power/fire button, the smaller one is the mode button. Hold down the mode button for at least 5-6 seconds and it should switch to yards instead of meters. (Y to M)
Good Luck!!!
MTG
Jun 20, 2009 | Bushnell Yardage Pro 600 Rangefinder
Bushnell 1500 pinseeker with slope+/- to go from M to Yards
Hold down the "MODE" button until the "M" starts to flash......touch the mode button again till the "Y" flashes........then touch the "FIRE" button on top.....(square button) Then it will be set to read in yards....not meters.
mtg
May 16, 2009 | Bushnell Pinseeker 1500 Rangefinder
Wrong type of measurement showing
On most of the bushnell units you just hold down the MODE button for about 5 seconds and the unit should switch from yards to meters....or vice versa
Mar 13, 2009 | Bushnell X-500 Rangefinder
How do I change Meters to Yards
with unit on- hold mode button down for five seconds
Jan 25, 2009 | Bushnell Tour V2 Pinseeker Laser...
Don't know what the ''Mode'' button is used for? Thanks
This mode hones in on the flag. Click it off when you are measuring distances to a bunker, tree, etc.
Nov 23, 2008 | Bushnell Pinseeker 1500 Rangefinder
Optics Logo
246 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
