Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Washer won't spin or drain.
By Jolantru on Oct 27, 2007
The washer fills and agitates but does not spin or drain.
Whirlpool Washer LA5558XSWO
Comments:
Oct 27, 2007
- Also, how do I take the washer apart?
Same Problem
Mar 12, 2008
-   Roper washer will do all cycles except the final drain just before the spin dry cycle. How do we fix this?-   DJYorkie
Dec 14, 2007
-   the led is on then it fills up water and machine doesnt start spinning at all
-   gfu1232004
Solution #1
posted on Oct 28, 2007
Not Helpful)
fixinit4me
Rank: Master
Rating: 85%, 10 votes
Was this helpful?
Yes
No
Solution #2
posted on Mar 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The problem is likely one of three things:
1. there is something clogging the line (poss a thin sock)
2. the belt is loose, broken or off
3. the pump is no longer functioning.
a quick test for each:
1. with the washer filled with water lower the hose to the floor, if water gushes out, this is not the problem.
2. inspect the belts, manually turn the bottom of the agitator and it will turn the other belts, the one under the pump should be turning the bottom of the pump.
* if it is not the above, likely the pump needs replacing.
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
I have a siemens washing machine - front load automatic. It is now winter here and it keeps showing... (More)
Answer
hello,7.5kg comercial,top load.when it starts the wash cycle it has a bad banging sound thats quit... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
