Question about Cooking
How to freeze asparagus - Cooking
Freeze asparagus raw?
has to be blanched raw it will rot .
May 11, 2016 | Computers & Internet
Can I freeze it raw?
Hi and yes you can freeze asparagus raw, The link below is worth reading.. CHEERS
Freezing Asparagus How to freeze fresh asparagus for the best quality...
How do I freeze asparagus
You can also learn other methods of freezing asparagus here
http://www.preservingyourharvest.com/FreezingAsparagus.html
Apr 23, 2015 | Miscellaneous
How do I freeze fresh asparagus?
http://www.asparagus-lover.com/freezing-asparagus.html
Feb 24, 2015 | Refrigerators
How do I freeze asparagus.?
Hello Anita;
My name is Peter. I am a retired field service refrigeration technician.
Both air and moisture are detrimental to all food storage, both in your fresh food section or your freezer. Leftovers in your fresh food section should be discarded after 3 days. In the freezer section they can last months depending on the food product.
It is nice for temporary storage to use items like tupper ware, but you can not get all of the air out of the container. It is better to leave the food product in the original bowl or place in a container where you can cover with plastic wrap, pushing down and making contact with the food product, getting rid of the air.
Your refrigerator temperature settings are critical. The fresh food section should be between 35-40 degrees F. and your freezer -2 to +2 degrees F.
Ok, lets freeze the asparagus. With a paper towel soak the outside moisture from the asparagus. Wrap it in plastic wrap ensuring there is no air in your package.
Do not put anything in your freezer or fresh food section directly in front of the air vents to avoid blocking air flow.
Nov 12, 2014 | Refrigerators
How to freeze asparagus?
Google it, it will come up
Jul 07, 2014 | Cooking
Freeze asparagus
Asparagus can be frozen easily,clean,rinse with clear water,blanch then freeze.Best if thawed in fridge like you would do with meat or just throw it in your microwave in a steamer for 8 to 10 minutes depending on the amount of asparagus.I put about 1 lb in microwave frozen solid for 8 minutes and it comes out pretty good,adjust your times for your likeness.
May 19, 2014 | Cooking
I love asparagus and really want to combine it with pasta in some way but have no clue what to do with it. Any recipe ideas?
I love this pasta with asparagus recipe. It's pretty simple but if your asparagus is fresh and tasty, it just is the best recipe for a light supper.
http://www.tasteofhome.com/Recipes/Pasta-with-Asparagus
Enjoy.
Feb 20, 2013 | Cooking
My problem is weeds in my asparagus bed. I have been told that after harvest, I can use Roundup to kill the weed growth. I would like to have the instructions to do this. I do not want to harm the...
The current Roundup formula effects the plants through absorption into the leaves. The easiest way is to simply wait for the asparagus to die back completely for the season before applying the herbicide. As the asparagus is dormant and without leaves the herbicide will not be absorbed and will not effect it.
May 26, 2011 | Roundup "" Weed & Grass Killer
Cooking Logo
Top Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Cooking Expert? Answer questions, earn points and help others
