Question about Octane Fitness Q47ci Elliptical Trainer
Error 22 on Octane 47
How do I fix the error 22 on my Octane 47?
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
The power supply o my TEM model CM30 is burned. I need to buy 2 of them. Here is some spec. type : PE1148/22 AC 110/230V 47-440Hz, 500 VA DC 50V 6A
Call FEI @ 866-693-3426 and order PN 4022 268 00415.
This is a replacement for the Obsolete PE 1148/22.
This replacement takes teh place of TWO PE 1148/22 units.
Some Wiring modifications may be required.
Jul 13, 2011 | Philips Computers & Internet
I have SandDisk S3 UCL Mode USB Device which is not detecting right now. One week back its working fine. In computer management i found device has in diabled mode. when i try to make it enable its again...
How to Fix a Code 22 Error
  1. Enable the device. Since the most common reason you'll see a Code 22 error in Device Manager is because the device has been manually disabled, try manually enabling it.
    Most of the time this will fix a Code 22 issue. Don't worry if it doesn't, however. All that means is that the Code 22 you're seeing was caused by something a bit less common.
  1. Restart your computer if you haven't already.
    There's always the chance that the error Code 22 you're seeing on a device was caused by a temporary problem with the hardware. If so, a restart of your computer might be all you need to fix the Code 22 error.
  2. Did you install a device or make a change in Device Manager just before the Code 22 error appeared? If so, it's highly likely that the change you made caused the Code 22 error.
    Undo the change if you can, restart your PC, and then check again for the Code 22 error.
    Depending on the changes you made, some solutions might include:
  1. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is one possible solution to a Code 22 error.
    Important: If a USB device is generating the Code 22 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Correctly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
  2. Update the drivers for the device. It's also possible that installing the latest drivers for the device could correct the Code 22 error.
    If updating the drivers does remove the Code 22 error, it means that the stored Windows drivers you reinstalled in the previous step were either damaged or were the wrong drivers.
  3. Clear CMOS. If Windows had to disable the device, generating the Code 22 error due to a lack of system resources, clearing CMOS might fix the problem.
  4. Update BIOS. Another possibility is that a newer BIOS version could better pass system resource handling to Windows, correcting the Code 22 error.
  1. Move the device to a different expansion slot on the motherboard, assuming of course that the piece of hardware with the Code 22 error is an expansion card of some kind.
    If the Code 22 error is due to a lack of system resources available for the card, moving it to a different slot on the motherboard could clear up the problem. This isn't as common a situation with newer hardware and Windows versions but it is possible and is an easy troubleshooting step to try.
  2. Replace the hardware. A problem with the device itself might be the root cause of the Code 22 error, in which case replacing the hardware is the next logical step.
    While not likely, another possibility is that the device is incompatible with your version of Windows. You can always check the Windows HCL to be sure.
    Note: If you're positive that the hardware is working properly and is properly configured then you might consider a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either before you replace the hardware, but you may have to give them a try if you're out of other options.
Please let me know if you've fixed a Code 22 error in a way I haven't mentioned above. I'd like to keep this page as accurate as possible.
What Does the Code 22 Error Apply to?
The Code 22 error could apply to any hardware device managed by Device Manager.
Any of Microsoft's operating systems could experience a Code 22 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 22 Issues in Device Manager?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more.
Be sure to let me know that the exact error you're receiving is the Code 22 error in Device Manager. Also, please let us know what steps you've already taken to try to fix the problem.
Show Full Article
Aug 03, 2017 | Computers & Internet
Cannot get license, because server returns error code:-47 NComputing Error
Nov 18, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
What kind of mileage should I be getting on a gt500 and how do I improve it?
what are you getting? The only thing you can do is drive easier, coast, dont accel hard ect. If you wanted good mileage, you bought the wrong car.
Nov 10, 2010 | 2009 Ford Mustang
Would regular grade gas ruin the motor?
Hi Thomas--
I recommend you use the highest octane available for small engines. Octane is a measure of a fuel's resistance to preignition. Small engines have no mechanisms to overcome a poor fuel's shortcomings, and you could foul pistons, rings, valves, and plugs without knowing it.
--Hope this helps.
Oct 07, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Lens error: 22
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 12, 2009 | Kodak EasyShare CD33 Digital Camera
Hp photosmart m425 lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 14, 2008 | HP Photosmart M425 Digital Camera
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Octane Fitness Q47ci Elliptical Trainer Logo
Top Octane Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
