Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer-piece inside drum came off and metal pieces are tearing the clothes
One of the three plastic feet pieces inside the drum has come off and will not go back onto the metal. Washer works but clothes get small holes where they hook on the metal
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Oasis, fabric softer thing exploded...
Okay...the cone actually goes inside the the two other pieces you mention. The cone is to be inserted upside-down. That is, the opening of the cone should be facing UP. The way this fabric softener dispenser is supposed to work is, you place fabric softener thorugh the opening of the dispenser. The cone actually holds it like a cup. When the washer goes through the initial spin cycle before the rinse cycle begins, the centrifugal force of the washer spinning forces the fabric softener out of the cone and into the wash tub.
The dispenser assembly should just snap right on top of the agitator. If the dispenser does not stay on securely any longer, you may have to replace it with a new one. You can find replacements at searspartsdirect.com. Just type in the same model number you provided and look for item number 1 under the "Motor, Basket and Tub Parts" heading.
I hope you find this information helpful. If you still have questions, please let me know.
PS It is also a good idea to periodically remove the dispenser and soak it in some hot water to get rid of accumulations of hardened softner. They will clog from time to time.
Posted on Sep 04, 2008
asish_shrm
  • 121 Answers
SOURCE: Kenmore 90 Series Washer
Hi!
looks like you have a defective motor or a leaked load capacitor .....you need to get the motor rewired....or get a new motor for your washer..... have the capacitor checked....
but ya the issue is 1 of the 2....faulty cap/motor
Cheers!
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: My front load kenmore elite 110.45872 shakes during spin cycle
your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Posted on Dec 20, 2008
SOURCE: Kenmore front load washer will not spin
Although I had just cleaned the filter about 5 weeks ago, my wife had recently washed a pillow that came apart in the wash. I did not know this but noticed the clothes dripping wet after the high speed cycle. I was thinking it was the drain problem like I read in the post from bluefuzz. I pulled the filter and it was LOADED full. Before calling the repairman, CHECK YOUR FILTER! You won't need to disconnect any hoses.
Posted on Jan 18, 2009
  • 662 Answers
SOURCE: Kenmore Elite HE 5t front load washer - F20 signal will not drain
http://www.fixya.com/support/r3608632-f20_error_code
Posted on Jun 04, 2010
Kenmore elite quiet pan 4 he4t plastic piece replacement
There can be a loose bearing between the drum and the outer wall of the machine but, there is definitely something loose. I know that this is not what you would like to hear but, the best advice anyone can give you is have your machine looked at by a specialist. Moreover, going to your washing machine retail store, should have the equipment you are looking for, or you can search for it online and compare prices.
Mar 21, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer troubleshooting
Sounds like your bearings are worn and need replacing... a horrible job. The frayed plastic may mean a new drum. To replace the bearings you must remove and separate the drum which requires removing the top, front, and back panels. Lots of clips, screws, hoses, wires.... I'd take it on if this were my unit; but for a client, I'd say get a new one. This is not uncommon for these units. Sorry.
Feb 16, 2014 | Washing Machines
Front loader washing machine inside hard plastic bar broke off
there are several kinds of plastic cement..everything from superglue to plastic pipe cement like plumbers use..available at most hardware stores..even model glue..I would try one of these before pitching the washer..you nmay be able to screw it on using stainless steel sheet metal screws also..
Jan 15, 2014 | Kenmore Washing Machines
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
How do your remove the drum in a Kenmore front-loading washing machine? A piece of metal got through one of the holes in the metal basket where the clothes go, and I am afraid it will block the drum from...
Disassembling this machine is a quite daunting experience that I would not suggest you attempt.
I'd rather suggest you get ahold of this metal piece with a pair of vise grips and try to pull it out manually, this may require using some force.... but if it went in, it will come out.
Oct 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Now the washer wont come on
remove bottom cover just below lock assembly will be a tear shaped plastic piece pull straight down door will unlock possible problem with pump out caused door to remain locked
Apr 15, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer putting black smears on clothes
The white plastic pieces just inside the font of the drum are the front bearings there are aboutfour of these, you will need to take the front of the machine to put them in, your clothes are probably picking up black smeres from where the plastis bearings have worn.
Oct 18, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
