Question about Sanyo Vpc-e2100bk 14mp 21x 14mp, Camera, Digital
Turn on the camera, shuts right off and beeps several times
Camera doesnt turn on, it lights up then beeps three times and then shuts down
The camera shuts itself down to protect itself for further damage since it detected a problem. Make sure your battery is fully charged. If yes, then do this little trick. Hold the camera with your right hand with the lens facing the ground. Next, tap the camera's base as you turn ON the camera. This aims to remove any grit of sand or dust stuck in between the camera's base and the side of lense barrel. You may have to do this several times and see it it works.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Samsung L100 Digital Camera
The camera beeps 3 times on startup and then shuts down...
You have dirt trapped in the lense mechanism. use compressed air can to blow it out then turn camera off ans slap it into the palm of your hand a few times and turn on again to test if it has cleared. This is not a joke it actually works. Lots of these types of cameras suffer from this problem and I have fixed them using this method. Passed on By a Canon Tech!!! It certainly worked for mine . Be persistent some work immediately others take several goes of blowing and slapping face down
Jun 22, 2009 | Samsung S860 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
Digital camera starts then shuts down
yeah its broken sorry mate
suggest a new camera
Dec 15, 2008 | Cameras
Camera turns off
you have to getdurecell battiries they work perfect..
Oct 11, 2008 | Polaroid i532 Digital Camera
Camera beeps loud 3 times and shuts right off!!
sounds like a lens error, does the lens extend or retract? You probably have to get the lens back on track, use gentle pressure wiht the camera face down on a towel covered table and turn on to see if the camera tries to retract the lens. I really dislike these types of cameras that extend the lens everytime, if it turns on in your pocket, your doomed!
May 27, 2008 | Samsung Digimax S500 Digital Camera
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Jan 14, 2008 | Samsung Digimax S500 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Sanyo Vpc-e2100bk 14mp 21x 14mp, Camera, Digital Logo
44 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
