Question about Duraflame L Electric Stove with Remote
Not working the unit stops heating and the blower shuts off continuely
    New Friend:
  • 62 Answers
There is a thermostat on the unit. it is probably set too low.
So the heater quickly hits the low temperature and shuts the heat off, then when the temp drop it will come back on.
Posted on Apr 01, 2015
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Heater won't turn off. I turned the thermostat all the way off and it continued to heat until I turned off the breaker
remove thermostat wires off the unit heater and if it stops running you have the red and white wires tuching somewhere in the wire,ore bad thermotat.
Jan 21, 2011 | Dayton G73 Utility Heater
Why does Blower in the inside unit continues to run non-stop? Thermostat set on Auto
Hi!!
If when the desired temp. is reached, the compressor and condenser motor (outside unit) will shut off but the blower in the inside unit will keep working when the thermostat is set to Auto, the problems could be 1 - thermostat unit defective, and 2 - blower motor starter relay defective.
Good Luck!! Don't forget to rate this post!!
Sep 21, 2010 | Heating & Cooling
Coleman eb15b blower fan will not shut off
The most common issue with this symptom and unit is a stuck blower relay.
Once the unit is reached temp and the heat elements stop the blower is to shut down when unit cooled. In your case the switchis stuck resulting in continuous fan.
Here is a manual that is real handy for troubleshooting electric funaces.
http://www.nordyne.com/Literature/359a.pdf
Mar 18, 2010 | Coleman Propane Forced Air Heater...
No heat/// blower works
First, check the duct work! The most common "no heat" problems with dryers are caused by duct work blockage. If your duct is blocked, it will overheat the unit, causing it to shut down the heat source (gas or electric, it doesn't matter). Most units will continue to "blow" without the heat. Remove the duct work, remove all lint from the duct and "exit" port of the unit. Then, check the wall duct, both inside and outside the house.
Feb 14, 2010 | Dryers
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
Heating
I had this same problem....The mechanic said I need the BLOWER replaced. I have a 2004 Pacifica, the part was 169.00 and 50.00 for labor.
Oct 30, 2008 | 2004 Chrysler Pacifica
Duraflame L Electric Stove with Remote Logo
336 people viewed this question
Top Duraflame Home Experts
ray gallant
Oliasys
Level 1 Expert
Michael Harrier
Are you a Duraflame Home Expert? Answer questions, earn points and help others
