Question about American DJ Dyno-Fog-II Fog Machine W/ Remote System
Low fog output
Shoots fog about one to two feet... I have another unit the same that shoots about five to six feet....  I took the unit apart and made sure the plastic line was clear.... used the cleaning fluid (1st time in 2 years) and drained the pump, wiped the front of the heater core.... put it back together and still no better... Don't know if there is something I can do to check or clean the pump or the heater core, short of sending it to California for repair?
kensen10@yahoo.com
  • Anonymous Feb 01, 2009
    THE UNIT WILL NOT THROW OUT MUCH SMOKE AT ALL.
I had the same problem with an American DJ, I removed the pump took it apart and cleaned it. It had a stuck valve in it. It now works fine.
Posted on Aug 18, 2008
  • Yaquelyn Sanchez
    Yaquelyn Sanchez Nov 01, 2013
    How did you take apart the pump
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Shoots realy low cant get it to raise enough
You'll need to shim it. Use 35mm film strips, piece of plastic,electrical tape for thicker pad until you can get close to zero with sight set to middle of it's travel.
Feb 10, 2013 | Browning Buckmark Holographic Sight...
Why is my cadillac seville 1996 fogging my inner windshield temperature gauge shoots to hot then under hood smoke then overheats
fogging inside is signs of a blown heater core be careful over heating that engine they blow head gaskets easy
Mar 26, 2012 | Buick Cars & Trucks
Senco Finishpro18 just stopped shooting nails. Took it apart, put it together. Shoots a couple of nails, then stops. press the nailer against the target, pull the trigger, and air comes out of the handle.
Do you regularly use air-tool oil placed in the air connection? If it gets a good workout every day, buy an 'inline' oiler that is inserted into the air line which automatically takes care of oiling. Hope this helps!
Mar 28, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Shoots liquid not fog
you need to let it fully heat up first!
Nov 15, 2009 | Fountainhead/Burgess Prod Black Flag...
Shoots out liquid instead of fog...
that thing(the heater) just doesn't work well,
bring it to someone to repair it
Apr 23, 2009 | American DJ Dyno-Fog-II Fog Machine W/...
CROSMAN 760 PUMP PELLET RIFLE REPAIR
How do you change the air cylinder
May 26, 2008 | Crosman (4032)
American DJ Vaporizer Fog hog
Sounds like the pump either is not working or can't inject the fog fluid ( solution of distilled water & glycerin ). My unit clogged up, so I took it apart and cleaned out the lines. Be sure to run pure distilled water through unit, after each use.
Oct 30, 2007 | American DJ Fogstorm 1700hd Fog Machine W/...
American DJ Dyno-Fog-II Fog Machine W/ Remote System Logo
544 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
