Question about Duraflame L Electric Stove with Remote
The heater and the blower do not stay on
The heater and blower stop working and do not stay on I have to shut the unit off and restart it but it keeps happening
Heater stays on when vehicle is turned off. Stays on when I remove the fuse also. Drained my battery while I was at work.
PULLING THE BLOWER MOTOR FUSE SHOULD MAKE THE BLOWER STOP. HOWEVER, THERE IS ALSO AN AC/HEATER FUSE THAT CAN KEEP THE MOTOR RUNNING. { IN FUSEBOX ON LOWER LEFT SIDE OF DASH }
Jan 18, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
Coleman eb15b blower fan will not shut off
The most common issue with this symptom and unit is a stuck blower relay.
Once the unit is reached temp and the heat elements stop the blower is to shut down when unit cooled. In your case the switchis stuck resulting in continuous fan.
Here is a manual that is real handy for troubleshooting electric funaces.
http://www.nordyne.com/Literature/359a.pdf
Mar 18, 2010 | Coleman Propane Forced Air Heater...
Driver seat heater only stays on for 15 seconds. If I only turn passenger seat heater on, passenger side works fine, when i add drivers side, both shut off. 2005 1500yukon XL Also heater blower just stoped...
No biggy.The seat heater can be repaired by the dealership.Should not cost much because there are no parts just a reprogram of the drivers seat module.The blower motor is the blower motor resistor module.It is on the passengers side under the dash next to the blower motor.You should be able to do this yourself if you have a little mechanical experience.Hope this helps.Good luck.
Jan 29, 2010 | 2003 GMC Yukon XL
2003 Dodge 1500 heater blower stop working and restarts most of the time after shutting the ignition off and restarting. It does this on all blower speeds. Occassionally shutting the engine off and...
you may need to replace the temp limited switch for the most part its close to the blower motor itself it has two small screws on each side with a plug in the middle give these websites a try www.autozone.com ane www.alldatadiy.com ifall fails stop by your local parts store and they be able to show you what ia ma talking about wish you the best of luck Michigan Man
Dec 11, 2009 | 2004 Dodge Ram 1500
Fireplace will not stay lit and pilot light is on
This sounds like the high temperature switch has failed and is telling the unit to shut down after it gets started, the pilot has to be lit for the main gas valve to turn on when the thermostat calls for heat, The main burner comes on and stays on until the thermostat is satisfied and tells it to shut off, you dont say if there is a blower in this unit, if there is a blower after the main flame comes on the unit heats up it turns on the blower if equiped. If the blower fails to turn on the unit would be shut down on overtemp as the firebox would get to hot and be in danger of causeing a fire. if no blower there still is an overtemp switch that shuts the unit down if it gets to hot or the switch is bad, it could be a bad overtemp switch or if equiped a bad blower motor or even a plugged chimney as this would also cause a overheat ing condition. Hope This Helps Don
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Williams Heater console floor unit
Is this a floor furnace? If so sounds like the switch for the blower, which is mounted on the side of the fire box is bad. There should be 2 of them, 1 for the blower to start 1 for the blower to stop when the fire box is cooled down. It wouldn't hurt to just replace both of them.
Oct 07, 2009 | Williams Heating & Cooling
2001 Chevy Blazer blower motor not working
It keeps burning out blower resistors because of the blower motor drawing to much amperage so you will need to replace the resistor and blower motor
Jun 27, 2009 | 1988 Chrysler Fifth Avenue
Aprilaire 760 keeps running.
The humidifier should not turn on untill the furnace blower starts. Since the fan stays on. does the solenoid valve also stay on? If they both stay on you probably have a bad humidistat. If only the blower stays on then the circuit bourd in the humidifier is defective.
Good luck
HVAC Teacher
Feb 06, 2009 | Aprilaire 700 Humidifier
Duraflame L Electric Stove with Remote Logo
57 people viewed this question
Top Duraflame Home Experts
Donni Steen
Tom Chichester
Are you a Duraflame Home Expert? Answer questions, earn points and help others
