Question about Pyle pro pwma2003t hybrid pre-amp w/am-fm tuner/usb/dual mic
Have a pyle pvma 2003 T and the sound output stop working ,any idea how to reset the unit or how to make it work again
2 Suggested Answers
  • 35 Answers
SOURCE: why my pyle 800 wats stop working after while when is in just
cud be a bad ground or ht is loose
Posted on Jul 16, 2009
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
Hi, Got problem with my amp. Sudenly it has stopped working. It is got a 2 x 20 amp fuses. One of them has blown up. When I have tried to change it , I have noticed that electric sparks and lightly smoke...
My guess is that you had it turned up so high for so long you melted something. This would be from large current draw over extended period of time with inadequate ventilation for the resulting heat. I have done this myself, so I feel your pain.
If you are feeling brave, you could open it up and look for any charred or melted wiring, and replacing it with a patch wire. If you see any evidence of scorching or melting on any of the circuit boards instead, it's not worth fixing.
Since it is a Pyle amp (which is actually just a re-branded Pyramid), it would probably cost the same to just replace it with a new one or from eBay.
Jason
Sep 21, 2011 | Pyle PLA2580 Car Audio Amplifier
LOCKED TOUCHSCREEN...
PYLE PLDN76DB locked screen fix that worked on my unit. Hold in the reset button with small pin on front bottom right hand corner, for about 5 seconds and hold "ON" button on remote control at the same time. When unit reboots itself my screen started working.
Jul 03, 2011 | Pyle PLDN76DB Car Video Player
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
Jbl 1100w amp no sound
a couple of things , there are sometimes fuses at the uput stage internaly or it sounds like you have bown the output stage or output i dont ko if it would be orth repairing as this is the ost xpensive part inside
Jul 20, 2009 | Pyle BZDBP212 Car Subwoofer
Wont play throught speakers only crakles everything hooked right maybe needs new wireing harness but everything works but sound
If everything is hooked up correctly, you may need to wire harness. It could be a bad capacitor in the audio outputs. Easy to try wire harness first. Sometimes turning off and back on again works.
Jul 08, 2009 | Pyle PLDVIN7 Car DVD Player
I stop getting power or sound to my sub
Double check your fuses. It sounds like you blew a fuse. Check the fuse for the radio aswell as the inline fuse for you amp. On some amplifiers there is a circuit breaker reset button. Check to see if your amp is equiped for that. I did find this quote for reset out of the owners manual.
Remote Turn-on
Automatically turns amplifier on when connected to the head unit's remote output. The
amplifier will turn on and off with the head unit to save current consumption. This control
also operates the reset circuit for the amplifier's protection. It must be connected with
the head unit in order to reset protection circuits.
Mar 28, 2009 | Bazooka BA1500 Car Amp
Can the Pyle PLCD-42
Yes there is a couple possible ways.
1. Get 2 RCA Y adapters and split your Preamp Output you will not have any type of fader control this way because you are using a single output.
2. Run one amp from the radio with a set of RCA Cables.
Hook up amp #2 using a Line converter connected to the output of your stereo which will convert you to RCA the just run a cable to the amp..
3. If one of the amps has a High Level Input Run a set of speaker wires from the stereo outputs to the High level Input.
I personally prefer the above 2 methods I find Low Level input sounds better.
Hope this gives you some Ideas and helps
Aug 31, 2008 | Pyle PLCD-42 CD Player
Pyle pro pwma2003t hybrid pre-amp w/am-fm tuner/usb/dual mic Logo
23 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
