Question about Sewing Machines
Is there a video or magnified view of the threading procedure for Phaff 4772 coverlock machine. I have the manual.
    Champion:
  • 276 Answers
Try looking on youtube
Posted on Feb 22, 2014
5 Suggested Answers
angie333
  • 5 Answers
SOURCE: My phaff industrial machine won't
hi my names anela . here a little solution for you to try. take the spool out of its case and place the case on a peice of paper draw around the case, and cut out. then cut out a smaller circle in the middle. and place back into the spoolcase this should help.
if not. then you prob have the needle in the wrong way round turn your needle so the long ridge is facing inwards . thanks angela
Posted on Aug 21, 2008
  • 132 Answers
SOURCE: I bought a Phaff sewing machine today. I do upholstery and for 20.00 could not pass up this beautiful gem. However I cannot find out anything about it. It says Phaff 6 on the front and I'm assumin
Here Ya Go:
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/0be5c9d6f43ae6b5852575f300539545?OpenDocument
Posted on Jan 14, 2012
Testimonial: "TY Darcy Would love to know what year machine this is if that is possible?"
SOURCE: I have a new Phaff Coverlock 4.0 Serger that I cannot get the box to come up on the screen to calibrate it. There is on stitch in there that coms up, but I cannot calibrate it to make the other stit
I would suggest taking the machine back to the one you bought it from & see if they have another one that will calibrate ,,& if they don't have one ,, I suggest another sewing machine dealer..
or you can try contacting Phaff customer support by phone or email & see what they say
Posted on Jan 30, 2012
Testimonial: "calling Phaff customer support was helpful."
SOURCE: How to Thread my Phaff 1528 machine
there are some threading diagrams on sewusa.com
or contact pfaff customer service about a manual
Posted on Mar 18, 2012
Phaff 1472 stitches are bunching up underneath
That is thread nesting or bird nesting. Could be the result of several things, but main reasons are upper tension too loose and the thread not being completely seated in the tension disk.
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Nov 17, 2016 | PfaFF Sewing Machines
How do I remove the left cover on a phaff 2140. the piece that covers the tension discs.
Don't know this machine but would avoid pulling anything off as screws have a habit of pinging out and never going back. Try pulling a thicker piece of thread or fabric through the tension disks to dislodge whatever is there first
Oct 02, 2015 | PfaFF Sewing Machines
I have gone crazy trying to use my Phaff 4852 Coverlock, it keeps breaking threads...help?? I have threaded it at least 10 times exactly following the instructions
1. Take your throat plate off.
2. Turn your hand wheel towards you while you look at the needle go before the plate and begins to rise again.
3. The thread should slide across the bobbin carrier/bobbin without getting snagged. If it gets snagged the brackets that hold the carrier in place are pushed against the carrier too tight. They have to allow the thread to flow.
4. Check the bobbin pressure. The bobbin tension should be equal to the top tension. Attempt to equal the tension of four if possible.
5. Put your pressure foot up.
6. While you thread the machine give little nudges to check for snags along the way. The thread has got to go through the tension disc without error.
7 Once threaded put your foot down. Pull a little bit on the thread. It should have some resistance. Lower and raise the tension to check if the resistance changes any.
8. Sometimes the tension disc has to be blown out. This is also true about the tension spring on the bobbin case. You might want to put something thin between the tension disc to ensure there is no lint stuck.
9. Make sure the needle is the right one for the thread being used.
Feb 26, 2015 | Sewing Machines
How to thread phaff 541 hobby
http://www.manualowl.com/p/Pfaff/hobby-541/Manual/184524
Feb 02, 2015 | Singer Sewing Machines
How to fix my coverlock from skipping stitches
Looper timing is probably out, maybe even a damaged looper. Take it in for servicing.
May 14, 2014 | Sewing Machines
Mar 17, 2012 | PfaFF Sewing Machines
Jan 30, 2012 | PfaFF Sewing Machines
Coverlock skipped stitches
I'm assuming this is a domestic overlocker machine and not an industrial coverlock. Getting the coverlock stitch to sew out evenly without skipping can be problematic apparently with these.
First, if you are sewing a knit fabric, change the needles to ball points and see if this resolves it.
If not, I would suggest trying EX705 needles (assuming that your machine takes the regular domestic 130/705H needle system). The EX are just extra long scarf at the back which helps with securing the stitch on the underside. There is also a SUX needle, which is same long scarf but a stretch needle; for knits particularly those with elastane in them.
Thread wise, try Maxilock brand. You may find a wooly overlock thread on the underside works too.
Nov 09, 2011 | Sewing Machines
How to thread a phaff 301 hobby
hi there,
9e43374.jpg this your sewing machine,well if you to learn more on internet explorer type the address of www.youtube.com the on search box type sewing machine. there a lot slide show to start sewing you can choose how to thread and wind bobbins and lot more.happy learning whli enjoy watching.
regards,don't forget to rate me and log in to fixya will serve you better. thank's
ps. if you want manual Download the HOBBY-301-420- Pfaff sewing machine manual: http://gotoes.org/sales/PfsffSewingMachineManuals/ViewInfo.pl?Paff=1&Sewing_Machine_Model=HOBBY-301-420-INSTRUCTIONS
Apr 09, 2009 | PfaFF Sewing Machines
Tension problem?
On the back of the machine near where the foot pedal plus in should be a metal tag with the numbers on it. As for a manual, try this..
www.2instructions.com
Mar 24, 2009 | Sewing Machines
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
