Question about HP Pavilion p6210f Desktop 26GHz 6GB DDR2 SDRAM Windows 7 Home Premium x64 (NY544AAABA)
Cursor stops at will I have to cut the main power and when I turn the compoter on it works fine
Cursor works right, until it stops and I can't move it. I have to cut power at the source and when I turn the computer back on it works fine until it stops cold again.
  • 60 Answers
Reinstall the driver software for your mouse or update to the latest version
Posted on Feb 15, 2014
3 Suggested Answers
prayag_78
  • 43 Answers
SOURCE: hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Posted on Jul 22, 2008
  • 36 Answers
SOURCE: HP Pavilion a867c turns on, then right back off.
Hello floatinggodd, if you computer turn off by it self that means you motherboard is bad needs to be replaced this model computer is 6 years old - manufacturing date 2004, this has nothing to do with virus.
Posted on Nov 27, 2010
Testimonial: "Thank you for your advice. This makes much more sense."
Cursor stuck
Something might be corrupted, like OS or application. There are too many variables, but try booting into Safe Mode by pressing F8 during boot and using System Restore. There you can choose a date to roll back prior to problem. You may have to try a few dates. Plus you can uninstall any programs that may have caused the problem.
Jan 25, 2013 | Acer Aspire 7745G-9823 Notebook
Avail z990 can't receive text messages
Please have a check with your service provider. If still no help, then try resetting the device.1.Power off the phone.2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.3.Use "Vol+" and "Vol-" to move the cursor up and down.4.Move cursor to "wipe data/factory reset", press "Back" key to select it.5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.6.The data will be erased.7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
WARNING: All user data will be completely cleared; the phone will be in a factory reset status.
Jan 02, 2013 | ZTE Avail Z990 - Black at&t Smartphone
Cant open my hard drive in my laptop
Locate the power cable and USB cable that came with your hard drive.
Connect cables to the appropriate locations on the back of the hard drive.
Sometimes a USB cable doubles as the power source, so you might not need a wall outlet to power the device.
Turn on your computer and allow your operating system time to load before continuing.
Plug the hard drive into the power outlet if necessary, but wait on powering up the device.
Connect the USB cable to the computer while the hard drive is in the "Off" position.
If the USB cable doubles as the power source, the device might turn itself on once connected.
Turn on the hard drive and wait until the hardware has been detected by the operating system. A message should pop up that lets you know new hardware has been detected.
Click on the "Start" menu and go to "My Computer."
Notice all your disk drives are listed in this window. The external hard drive should be visible, and holding the mouse cursor over the location will help you locate the correct drive.
Right click on the location of the drive, and move the cursor to "Open" or "Explore" and click.
Hope this helps
Sep 26, 2012 | Transcend StoreJet 25 Mobile 500GB USB 20...
Cursor only works for 5 min., then it stops.
there may be a mouse port problem try checking ur ps/2 port by a loopback plug.if not replace ur mouse.
Apr 18, 2009 | Computers & Internet
Wacom Bamboo stylus shaky cursor
Ur issue is that the tablet itself can not be above the tower or the laptop. Magnets make it shake. I had that problem to anytime it was by the computer (only above for some reason) or by something magnetic, so avoid that and you should be fine.
Dec 12, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 08, 2008 | Logitech Wheel Mouse Optical
Samsung tv le37r8
Using a monitor
1..connect computer/media center to your monitor,
2 click on nvidia nview display settings,
3, select the current display tab and samsung,
4 then apply,
5,then when the confirmation box appears click yes within 15 seconds.
Using your samsung.
Attach a scart to your media centre, from your t.v with the p.c cable still attached, turn over using the source button until you can see a pc picture on your screen (EXT1or2), do steps 2 & 3 THEN move your cursor to the apply button (do not move the cursor from this position), press your source button till you get PC channel (which has no picture yet) then press your mouse button to apply, ( your picture will flicker on), and before the picture goes confirm with the yes button. You now have light! eureka :)
Jan 01, 2008 | Televison & Video
Convergence settings
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Pairing my Macally BT micro mouse
Q: After pairing my mouse, the button click works but cursor tracking does not move. What can I do?A: The cursor tracking problem is because red sensor LED is not on. Please try another set of battery or fully charge battery again, and verify if bottom red LED turns on. If red LED still does not turn on, please remove batteries from mouse, press and hold the pairing button for 5 seconds, next press and hold the left and right buttons simultaneously for 10 seconds, followed by several clicks. Install the battery into mouse, you should see red LED turns on, mouse cursor will move.
Oct 03, 2007 | Macally BTMicro Mouse
HP Pavilion p6210f Desktop  26GHz  6GB DDR2 SDRAM   Windows 7 Home Premium x64 (NY544AAABA) Logo
50 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
