Question about Bosch 24 in. SHX46A05UC Built-In Dishwasher
How does one replace the drain hose, the hose broke and I have ordered another hose. But I cannot find any instructions as to how the hose is to be removed. Can anyone help?
Model number SHX46A05UC/14 FD8312
4 Suggested Answers
SOURCE: Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
heatman101
  • 43501 Answers
SOURCE: My Bosch Dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 21, 2010
  • 414 Answers
SOURCE: mod shx46a05uc-14 at the end of cycal unit is making nois and you can open door unit dont shut down also at this time unit is empty and should have element on sounds like drain pump is on
Sounds like you either have a leak which has activated the flood safety in the base, you can check this by pulling the machine onto a towel and tipping the whole unit forward ie raise the back of the machine off the floor so it is pivoted on the front feet at approx 45 degrees, if water runs out from under the machine you have a leak (the machine may well start to work again now but you need to trace the leak or it will reoccur as soon as the safety is activated again). The other possibility is the pressure chamber or hose (pressure chamber to sump) is blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Posted on Feb 23, 2013
Need to replace the radiator on a 2004 gmc Yukon Denali 6.0 where is the drain plug located?
Just "yank the lower hose with a BIG drain pan under it." (from what I read).
Feb 04, 2018 | GMC Cars & Trucks
Drain hose broke.
you can get a drain hose joining fitting at most diy stores for a quick
fix.Otherwise replace hose.
Mar 07, 2015 | Washing Machines
Why won't my Maytag washer A48t drain? Replaced belts when it also wouldn't spin. Now it spins, but does not drain.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed. Also check drain hose.
Apr 24, 2014 | Whirlpool Washing Machines
Vcff136ss freezer drain hose
look at the bottom in the back for a small (usually black) rubber hose. this wil be the drain and the only way to clean them that I am aware if is to blow up through it ( makes amess inside the freezer or fridge but does work. some models drain the freezer into a funnel like thing on the back wall inside the fridge and then to outside.
Jan 02, 2014 | Viking VCFF136SS 36" Professional Series...
The washer broke filled with water and won't drain
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Sep 28, 2012 | Kenmore Washing Machines
It has broke and wont drain
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Challenging Instructions And Things You'll Need:
  • Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
please rate this if this help?.
Thanks for using fixya.
Dec 13, 2010 | Washing Machines
How do you pull out the RV refrigerator to replace the drain hose. Our hose broke.
back access panel remove feel up back of fridge pull off hose and replace
Oct 10, 2010 | Dometic RM2652 Refrigerator
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
Mar 13, 2010 | Maytag MDB9600A Jetclean II Built-in...
Broken fitting
You don't have to change that piece,just tie the hose (drain hose ) to something that is equal height,this prevents siphoning.
Please Rate This !
Jul 15, 2008 | Danby 22 in. DDW396 Free-standing...
Dishwashers Logo
23 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
